Old 01-18-2013
nmejicano's Avatar
Capt Nery
nmejicano is on a distinguished road
Repacing centerboards on a Gemini M
I purchased a 1996 Gemini 105 M about 3 months ago. It needed new boards. I just got them made at Chesapeake Light Craft. Now, I have some instructions, but they might as well be in Aramaic or Sanskrit. I will be hauling the boat out of the water about mid February and I wonder if anyone has undertaking this task. I am in the South Florida area and would appreciate some guidance. Also have some questions about the rigging and the asymmetrical spinnaker sock.
  #2
Old 01-18-2013
kd3pc's Avatar
kd3pc is on a distinguished road
Re: Repacing centerboards on a Gemini M
two ways.
one is to get the boat up high enough (rack and rig or sling time, but the process is time consuming ie. greater than a couple of hours unless you have tools and materials and have done it before) dropping the old boards, reinstall the new.
two, you can block the boat normally and trench a path to a hole beneath the ama, and then drop the old and replace with the new.
Make sure you have correct hardware and tools. I would contact Gemini and spare the hardware well in advance and simply replace it while I was in there...rather than expecting to remove/reuse the existing set.
two man job for a while, unless you are going to run back and forth and rig something to hold things in place.
  #3
Old 03-14-2013
nmejicano's Avatar
Capt Nery
Well I finally dropped the old centerboards. I had to drill a 4" hole on to access the pivot bolt. I am placing pictures and descriptions of the work being done on About Time, my 1996 Gemini 105 M. You can find my progress or lack of it at: About Time Sailing - www.about-time-sailing.com any comments, advise, suggestions, criticisms are welcome.
  #4
Old 03-14-2013
chucklesR's Avatar
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
Are you a member of the Gemini group on Yahoo?
Gemini_Cats : Gemini Catamarans
Lots of info there
(former owner of Hull 987)
Read, laugh, learn, or just enjoy
  #5
Old 03-14-2013
nmejicano's Avatar
Capt Nery
Yes, I am a member. I have not yet joined the Gemini Gems paid site.
You may post attachments
You may edit your posts
Annapolis Gemini Quality vs. Hunter Gemini Quality zboss Boat Review and Purchase Forum 10 10-27-2011 10:14 AM
repacing companiponway boards with 3/4" plywood timmydad Gear & Maintenance 20 11-12-2008 01:34 PM
Centerboards Hartley18 Sailboat Design and Construction 1 05-16-2008 06:42 AM
Where have all the centerboards gone? CapnRon47 Boat Review and Purchase Forum 23 08-01-2007 02:40 PM
Centerboards JakeLevi Boat Review and Purchase Forum 19 11-05-2006 09:29 AM
SEO by vBSEO 3.6.1
