Painting Sequence - SailNet Community
 3Likes
  • 3 Post By tommays
post #1 of 5 Old 01-18-2013 Thread Starter
Painting Sequence
I pulled my Endeavour 32 out of the water yesterday. My plan is to paint the topsides with Interlux Brightside and the bottom with Bluewater copper 45. My question for you is-- should I paint the bottom first? The topside first? Or does it make any difference?
algee is offline
post #2 of 5 Old 01-18-2013
tommays's Avatar
Re: Painting Sequence
I would prep EVERYTHING and keep in mind the paint rarely runs UP
Faster, redline and rugosa like this.
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #3 of 5 Old 01-19-2013
Nice work! How did you apply the paint? Was it roll and tip or spray? How many coats of paint did you apply?
ambianceack is offline
post #4 of 5 Old 01-19-2013
tommays's Avatar
I sprayed the 545 primer as while it has a certain level of danger its pretty easy to control
The Awlgrip topcoat was two coats roll and tip as the stuff is just crazy dangerous when your dealing with a 29' boat
The roll and tip work window is much bigger also
Tommays
Northport NY
tommays is offline
post #5 of 5 Old 01-19-2013
Al,
I doesn't look like you got an answer.
Top first because it may run down. Also, many boat use a white topside paint and a dark bottom paint. It's much easier for dark to cover light than vice versa. Another reason is that with the topside you want to be careful with the finish and not worry so much about the waterline, so just overrun that with the topside paint. When you can shave in the reflection, carefully apply painters tape to establish the waterline and boot stripe and paint away. Use good quality painters tape. $15/roll is money well spent. One thing to keep in mind as you're selecting paint is some are incompatible. If it has been painted and you don't know what's on it already, use a single part like EasyPoxy. If you know that it's a 2-part epoxy already (or bare fiberglass) use 2-part poly like Interlux Perfection.
DonScribner is offline
Proper start up sequence engine/battery RavenKing Electrical Systems 14 08-31-2012 08:41 PM
Smart Sequence AFTER Buying First Boat juggleandhope Boat Review and Purchase Forum 13 07-31-2012 02:17 PM
Top Painting lapworth Gear & Maintenance 14 01-25-2010 05:28 PM
Stuffing Box - sequence of events rperret Gear & Maintenance 5 05-12-2008 01:43 PM
Painting AirborneJarhead Gear & Maintenance 2 09-30-2006 08:18 PM
