Removing old thru-hulls - SailNet Community
 1Likes
  • 1 Post By Lake Superior Sailor
post #1 of 5 Old 01-19-2013 Thread Starter
bratzcpa's Avatar
I'm making my way through my winter project list. One such item is to remove and permanently plug three unneeded thru hulls. These are all the old gate valves, handles rusted off, non-working, etc. They gotta go (obviously). Here are pictures of two:
So, my question is "How do I remove thse things"? No threads available. It appears that the pipe fitting is actually glassed in. I am thinking of using a dremel tool with a cutoff wheel and cut off the pipe flush with the inside of the hull. . . . and then glass it over.
Any other suggestions or cautions or hints?
thx, markb
~markb
S/V "New Girl" on the dock
Catalina 27
bratzcpa is offline
post #2 of 5 Old 01-19-2013
Lake Superior Sailor's Avatar
Re: Removing old thru-hulls
Remove pipe fittings, check with hammer and chissel if there is a buryed nut on inside, use grinder and tap out with hammer to outside. I would grind outside clear of paint and expose brass flange. .....Dale
SloopJonB likes this.
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #3 of 5 Old 01-19-2013
redline's Avatar
I helped a friend remove an old transducer sleeve from his hull. It had a flange outside and an inside nut which is either seized or epoxied. Finally used my Dremel with a cutting disk to go inside the opening from the exterior and cut outwards around the circumference of the tube until the inner and outer halves could be separated. There may be other ways, but that worked for us.
Alternately, stuff a broomhandle or somesuch into the opening to give something for the center bit of a hole saw to grab, then drill out the entire thing a little oversize - since you're planning to remove it and plug the hole anyway.
Norman
s/y "Redline"
1998 Jeanneau SO45.2
redline is offline
post #4 of 5 Old 01-20-2013
I think you are on the right approach to remove the old valves and make the areas water tight. if that were my project I would sand a circular beveled area away from the valve/thru hull on both the inside and outside. it might be tough when working inside due to limited space but bring it down a little but not much, say quarter to half inch to get the glass off the thruhull. If you use a grinder do so with caution. Grinders remove too much to fast. I have a festool Rotex 150 sander that can take away a lot of material but provides good control. A dremel sander would also work.
NOTE: you do not want to remove all the material around the thru hull, just enough to get down below the surface. the bevel should be about 12:1. That is, if your diameter of the thru hull is about an inch create the circular bevel out about 12 inches from the center of the hole deep enough to expose the face of the thru hull (i.e., on the outside of boat). see if you can use a step wrench on the outside of the thru hull while trying to turn the gate valve. you might have to chip away paint around the steps in the thru hull. you will need a helper for that part of the job. if it doesn't move remove the gate valve, if frozen you may need some heat to break the rust, be careful do not hold heat for to long. I have used a sawzall to make three vertical cuts spaced evenly in the thru hull being careful not to cut into the fiberglass of the hull then use a small pry bar or old flat head screwdriver to pry away the pieces of the thru hull. You might have to modify the metal sawzall blade to fit your opening.
Once out clean the fiberglass with a good solvent like acetone. fill hole with a thickened epoxy. a good thicking agent would be collidial silica, then rebuild the beveled area with wetted fiberglass cloth, probably 6 oz. will work, then use a fairing compound, and and smooth areas to match existing hull shape, cover with one or more coats of barrier paint then bottom paint. Inside same procedure except barrier and bottom paint. Other good sources for this type of project are Maine Sails website and West System Epoxy/Gougen Brothers. There are other epoxies I just prefer west system.
ambianceack is offline
post #5 of 5 Old 01-20-2013
RichH's Avatar
For a non-recessed mushroom profile (external) through hull .... Use an angle grinder from the outside of the hull, grind off until flat with the hull, then punch the remaining part through. Use a 'deep socket' of the same OD as slightly smaller than the 'hole' as the 'punch' and use a manly sized hammer.
If recessed and flush to the hull profile through hull .... cut it from the 'inside'.
Use a heavily water soaked turkish towel wrapped around the valve to help cool and prevent heat damage to the FRG, etc. Don't grind away in one 'fell swoop' but allow intervals of good heat transfer into the wet towel, so that you dont overheat/damage the FRG.
RichH is online now
New thru hulls .. is this ok? smp Gear & Maintenance 27 04-11-2012 05:10 PM
More than 3 hulls? Ever been done? TintedChrome General Discussion (sailing related) 19 10-09-2010 07:09 PM
16' hulls jackie19 Gear & Maintenance 0 06-24-2010 01:26 PM
Through hulls drynoc Gear & Maintenance 5 08-14-2006 01:47 PM
Through-hulls? trecksail Gear & Maintenance 4 04-11-2006 01:28 PM
