lowest drag for fixed 3 blade? - SailNet Community
Blogs
Old 04-18-2004
e31 e31 is offline
e31 is on a distinguished road
I have an Ericson 31I with a 15" fixed three blade prop. Being that a self-feathering prop is out of the budget, what is the lowest drag situation for this fixed 3-blade gear:
1- freely rotating
or
2- locked in the "mickey mouse" position with two blades up and one inline with the keel?
or
3-quit worrying about the details and just sail.
Any thoughts?
Doug
Old 04-19-2004
39512's Avatar
39512 is on a distinguished road
How about a used two blade fixed prop? I suspect that there are some out there, since it is a common refit to change to a folding two blade prop.
Otherwise, I think it should be locked. You might find which position is best by marking the shaft with two blades up and two blades down then testing.
Old 04-19-2004
PaulBl is on a distinguished road
A fixed prop has about the same drag no matter who makes it. You can vary the diameter or the picth but thats all there is.
As far as locked or unlocked goes. It is more important to consider the transmission. My Hurth transmission requires the transmission locked in reverse so the prop does not freewheel under sail. Not all transmissions are like that so you need to find out. Some others can freewheel fine.
As far as if you can freewheel if it better I''ve seen it argued both ways. Since I have to lock mine I don''t care<g>.
If I had the money I would go with a Martec 3 blade. For now I lock the prop and just sail the boat.
Old 04-19-2004
jkumin is on a distinguished road
A German University ran tests a few years ago on several folding and feathering three bladed props. They used a fixed three blade as a control. At 8 knots the fixed prop drag was 420 Newtons locked and 180 free-wheeling. By contrast the better low drag (folding or feathering) props were around 12 Newtons drag. A Newton is around .22 pounds.
The point above is correct about transmissions - some need the input shaft turning for proper lubrication. There is also the noise and wear issue. Always nice to hear that low rumble stop when the prop
is locked.
Windward performance deseely General Discussion (sailing related) 16 01-28-2010 07:16 PM
2 blade or 3 blade propeller ddilman General Discussion (sailing related) 3 02-12-2006 01:45 PM
2 blade or 3 blade propeller ddilman Gear & Maintenance 14 12-29-2004 08:12 PM
2 blade or 3 blade propeller ddilman Boat Review and Purchase Forum 3 11-07-2004 08:27 AM
what if ! KenD General Discussion (sailing related) 40 02-11-2003 07:56 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
