Mini Through Hull for mast rain catcher - SailNet Community
post #1 of 14 Old 01-19-2013 Thread Starter
Glad I found Sailnet
Bene505's Avatar
I bought a small acrylic box to catch rainwater coming from the keel-stepped mast. I'm mounting it on the side of the grid that the mast sits on. Now I'm looking for a "through hull" for the box, so I can run a tiny hose into the main bilge, and not into the (preferrably dry) forward bilge.
Does anyone know where I could get something like this? I'm not sure what to call it on searches.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #2 of 14 Old 01-19-2013
rugosa's Avatar
Re: Mini Through Hull for mast rain catcher
hose diameter?
rugosa is offline
post #3 of 14 Old 01-19-2013
overbored's Avatar
I think what you are describing is a tank or bulkhead fitting most marine or plumbing supplies will have small ones.
"GOLD RUSH" PRINDLE 16
overbored is offline
post #4 of 14 Old 01-20-2013
Think you want a "uniseal slip fitting", couple of bucks should come
fairly small sizes...try Tank Depot...or Plastic Mart should be cheaper than marine stores.
Have used a wick for moving water up and over in similiar application.
HUGOSALT is offline
post #5 of 14 Old 01-20-2013
davidpm's Avatar
What did you use for a wick?
davidpm is offline
post #6 of 14 Old 01-20-2013
Can use any number of fiber cloth ...lantern/tiki torch wick, felt,
piece of carpet. I used strands from my wife's old mop (big spender
that I am). Moves small amount of water up a little and over horizontal a little more away from base of compression post into bilge. Thought that that one or another type of braided line
would work well but have not tried.
HUGOSALT is offline
post #7 of 14 Old 01-20-2013
Bene. I would love to see a pic of your setup.
I have a continual problem of water coming down the mast. In the winter, I remove a nearby thru hull, but its not working as well this year. Maybe the boat is slightly listed toward the other side this time. I have an inch of accumulated water throughout the bilge and I fully vacuumed it all out after the cover went on.
Jeanneau 54DS
Minnewaska is offline
post #8 of 14 Old 01-20-2013
tommays's Avatar
We were up at mcmichaels on the J70 demo day and when looking around the brokerage yard we and talking to them they install a 1/8 NPT drain plug in all there regular winter storage boats to deal with the problem of sneaky water
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #9 of 14 Old 01-21-2013 Thread Starter
Bene505's Avatar
It looks like bulkhead or tank connector is the way to go.
Online there are big ones, I'm thinking there may be smaller ones at a local hardware store.
Thank you for the help!
I'll post pictures once the project is done.
Regards,
Brad
Bene505 is offline
post #10 of 14 Old 01-22-2013
Old as Dirt!
svHyLyte's Avatar
Regards,
Brad
Brad. Check the US Plastics web site. They may have exactly what you need.
svHyLyte is offline
rain water entering bilge thru mast. mschpero General Discussion (sailing related) 45 01-05-2013 07:17 PM
Sound like rain coming from the hull chris31519 General Discussion (sailing related) 31 11-30-2009 11:50 PM
Rain Catcher? Anyone? marinegirl405 Living Aboard 19 05-18-2009 08:15 AM
barnegat bay MINI MINI Vous davidj.hellmuth Island Packet 5 02-09-2007 08:29 AM
Rain water coming in through the inside of the mast? DelmarRey Gear & Maintenance 7 04-23-2003 09:06 AM
