What is this on the aft end of the keel - SailNet Community
post #1 of 8 Old 01-20-2013 Thread Starter
davidpm's Avatar
C&C center cockpit.
What is it's function?
davidpm is offline
post #2 of 8 Old 01-20-2013
Re: What is this on the aft end of the keel
A grounding plate of some sort?.. a 'cover-up' repair?... guard plate in case they backed up onto a hard surface?...
Faster is online now
post #3 of 8 Old 01-20-2013
Lake Superior Sailor's Avatar
So what do you think? A ground plate or a grounding plate? got any wires hooked to it? maybe just a repair--Got me baffled!...Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #4 of 8 Old 01-20-2013 Thread Starter
davidpm's Avatar
Seems an odd way to handle a repair. A little epoxy and fairing would be easier and cheaper.
davidpm is offline
post #5 of 8 Old 01-20-2013
Whats the water line look like? maybe the low spot on the boat, bottoming point?..Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
post #6 of 8 Old 01-20-2013
Agree... and on a C&C that ought to be a bolt-on lead keel (or did the Landfalls use encapsulated ballast? not sure....)
Which model exactly?
post #7 of 8 Old 01-20-2013
chef2sail's Avatar
Wonder if its some kind of dyna plate
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #8 of 8 Old 01-20-2013
Not likely to be grounding shoe, would be on bottom of keel
and more robust.
Seems odd exposed place for ground plate.
That pretty much leaves repair of some kind, people do
odd things, if lead keel not bad, if ferrous not good.
HUGOSALT is offline
Seafarer 24 swing keel, keel pivot? Sailing qualities? skygazer Boat Review and Purchase Forum 44 10-21-2013 10:50 PM
Questions about barrier coat on steel keel, and sealing keel joint EricinToronto Gear & Maintenance 1 04-21-2012 10:43 PM
Full Keel vs. Wing Keel small boats Kyhillbilly General Discussion (sailing related) 4 07-26-2011 12:51 PM
How does a fixed keel boat differ from keel+centerboard? phboujon General Discussion (sailing related) 9 06-11-2009 11:29 PM
Swing Keel or Fixed Keel for Caribbean Sailing SailorJim123 Boat Review and Purchase Forum 1 02-04-2009 11:15 AM
