Old 01-22-2013
MarkSF is on a distinguished road
Calculating true wind
I have a Simrad is20 wind transducer and display. The display is on the NMEA 2000 network, and is using the SOG and COG from the chartplotter, to calculate true wind.
Am I right in thinking that I really need a heading sensor to calculate true wind accurately?
I think that the calculation is assuming that the boat's heading is the same as the course, which is erroneous if there is a current at any angle to the heading.
So I think I need to use heading, and GPS SOG. Is this right?
Bristol 31.1
  #2
Old 01-22-2013
kellysails's Avatar
Puget Sound Pounder
kellysails is on a distinguished road
Re: Calculating true wind
I believe you are correct. This site details it.
True Wind Speed And Direction Calculator
  #3
Old 01-22-2013
kellysails's Avatar
Puget Sound Pounder
OTOH, the heading provided by the GPS on the chart plotter should be good enough to calculate true. Although it likely does not update as quickly.
  #4
Old 01-22-2013
The GPS does not provide heading, it only provides course. It's dumb, in that it thinks the boat is pointing in the direction it's going....
Bristol 31.1
  #5
Old 01-22-2013
kellysails's Avatar
Puget Sound Pounder
Hmmm, so wouldn't the NMEA ($GPVTG - Track made good and ground speed) serve as the current heading? It seems as though the GPS is reporting TMG via Magnetic heading. Jeeze I could be all wet here. But I remember even my ancient old GPS's would provide the current Magnetic heading.
$GPVTG
Track Made Good and Ground Speed.
eg1. $GPVTG,360.0,T,348.7,M,000.0,N,000.0,K*43
eg2. $GPVTG,054.7,T,034.4,M,005.5,N,010.2,K
054.7,T True track made good
034.4,M Magnetic track made good
005.5,N Ground speed, knots
010.2,K Ground speed, Kilometers per hour
eg3. $GPVTG,t,T,,,s.ss,N,s.ss,K*hh
1 = Track made good
2 = Fixed text 'T' indicates that track made good is relative to true north
3 = not used
4 = not used
5 = Speed over ground in knots
6 = Fixed text 'N' indicates that speed over ground in in knots
7 = Speed over ground in kilometers/hour
8 = Fixed text 'K' indicates that speed over ground is in kilometers/hour
9 = Checksum
The actual track made good and speed relative to the ground.
$--VTG,x.x,T,x.x,M,x.x,N,x.x,K
x.x,T = Track, degrees True
x.x,M = Track, degrees Magnetic
x.x,N = Speed, knots
x.x,K = Speed, Km/hr
  #6
Old 01-22-2013
tommays's Avatar
You are trying to do something far more complex than it sounds
Which is why systems use the through hull knot meter as the boat speed when doing the math on the speed and direction the masthead sensor supply's
The above INFO is whats happing to the sails at that moment in time which is the purpose of the system
Unless somethings really changed my Chartplotter has current stations and can tell me to react as the current changes the course cross
BUT lacks the ability to pick the correct course from (and compensate for current ahead of time ) Northport TO Mamaroneck which is a fairly easy thing for and experienced navigator to do
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
  #7
Old 01-22-2013
Jeff_H's Avatar
Administrator
Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about
The reality is that the speed and course over ground will give you a closer to real True wind, in other words the wind that you would feel if you are anchored.
But for most sailing applications, and more specifically oddly enough for most racing applications, the instruments produce a "true wind" which is really a wind velocity that is not corrected for current, in other words, the wind that you would feel if you were drifting with the current.
Both are useful tactically but neither are extremely useful for sail trim or even for sail selection.
  #8
Old 01-22-2013
Hudsonian is on a distinguished road
Although there is not complete agreement is regarding usage, I believe that "true wind" is the wind that you would feel if drifting with the current. "Ground referenced wind' is the wind that you would feel if at anchor. Therefore, if you set aside leeway, the instruments can compute "true wind " velocity and direction with merely with velocity of the boat through the water, apparent wind speed, and apparent wind direction. Of course, the apparent wind and true wind are relative to the boat.
  #9
Old 01-23-2013
Omatako's Avatar
Omatako will become famous soon enough
Sorry I don't agree and go as far as saying that reality is diametrically opposite to your description
If the boat is effectively stationary and drifting on a tide, the GPS will give an accurate reading of the direction and speed of the boat's movement. GPS is far from dumb.
Equally if you are sailing a compass course of say, 165 degrees and there is a 090 degree current setting, the steering compass will read 165 (assuming it is accurate) and the GPS will read a vectored course including the current drift.
In other words, the compass will tell you where the boat is pointing and the GPS will tell you where you're going.
And I agree with Tommays - what you're trying to do is beyond the realm of a pocket calculator.
Arthur C. Clarke
  #10
Old 01-24-2013
Omatako's Avatar
Sorry, a bit confused.
If the wind instrument is working on its own, then the wind speed you are reading is pure apparent speed, nothing to do with true. The only time the wind in this condition can be considered true is if the boat is guaranteed to be stationary i.e. anchored. The true and apparent become one. As soon as the boat begins to move in any direction, the wind is apparent and not true.
Only if a boat speed indicator is working in the same NMEA system with the wind speed and direction can the readings be vectored to produce true wind speed. And the calculation of true wind speed done by the wind instrument and the boat speed indicator working together has no reference to course or heading or any other such dimension.
How do I know this? I had a protracted argument years ago with Sailing Dog who successfully proved that I was wrong and the correct answer is as outlined above.
Arthur C. Clarke
You may post attachments
You may edit your posts
ST80 Shows No Difference Between True/ Apparent Wind OffshoreDreamer Gear & Maintenance 8 08-03-2012 07:58 AM
True Wind vs Crazy Speed Transducer bacampbe Electronics 16 10-15-2009 10:17 AM
calculating Leeway freediverGA Lake Huron 2 05-28-2009 08:50 AM
True Wind Speed and Direction SEMIJim Gear & Maintenance 34 12-01-2008 05:28 AM
Calculating Your Electrical Load Kevin Jeffrey Gear and Maintenance Articles 0 03-03-2003 07:00 PM
SEO by vBSEO 3.6.1
