Best way to attach keel cable? - SailNet Community
 1Likes
  • 1 Post By JMN412
post #1 of 8 Old 01-22-2013 Thread Starter
JMN412's Avatar
Right now I have two stainless wire rope clamps keeping my keel cable attached. It has served well while I was working on the boat, but I am nearing the end of my restoration, so I want to make sure I have something that will hold up when I put the boat in the water, and I'm worried that isn't the best set up to have when sailing.
For others out there with swing keels, how do you have your cable attached?
canuck likes this.
JMN412 is offline
post #2 of 8 Old 01-22-2013
TQA
Bombay Explorer 44
TQA's Avatar
Re: Best way to attach keel cable?
3 SS bulldog clamps, but like youi I wonder if this is best. Thought about a SS swage?
TQA is offline
post #3 of 8 Old 01-23-2013
I don't discuss my member
zz4gta's Avatar
Why not replace the SS with dyneema and splice a ss thimble in it?
Merit 25 # 764 "Audrey"
zz4gta is offline
post #4 of 8 Old 01-23-2013
denverd0n's Avatar
A properly done swage is better than clamps. A poorly done swage is worse than clamps. If you go to swages, be sure you get them done by someone who knows what they're doing!
denverd0n is offline
post #5 of 8 Old 01-23-2013
Senior Moment Member
SloopJonB's Avatar
Can you use one of the compression fittings like a Norseman or Hy-Mod instead of a swage in that application?
SloopJonB is offline
post #6 of 8 Old 01-23-2013
TQA
Bombay Explorer 44
TQA's Avatar
What material would you recomend for the swage.
Remember it is going to be in or near the spalsh zone.
TQA is offline
post #7 of 8 Old 01-23-2013
SloopJonB's Avatar
I'd think that bronze or Monel would be best but I doubt they are available - I'd imagine S/S is going to be the only real option for a fitting.
Otherwise I guess a spliced eye.
post #8 of 8 Old 01-24-2013 Thread Starter
JMN412's Avatar
But the clamps are a viable option? I just don't want to have the clamps fail while I'm out on the water
JMN412 is offline
Tags
keel , keel cable , swing keel , wire rope
Spirit 23 Swing Keel Cable Mod Dwg windyway North American Yachts 18 07-04-2013 02:35 AM
Swing Keel Cable Broke Solarwatts Gear & Maintenance 9 07-09-2012 11:48 AM
Windless cable size, cable manufacture and battery type? SanDiegoChip Gear & Maintenance 25 02-19-2010 10:44 AM
cable on keel and wood in deck Flatfendershop MacGregor 4 11-20-2008 11:54 PM
Keel Cable/Tow/NavigationLoss VTNismoZ Gear & Maintenance 1 06-20-2005 01:32 PM
