Underwater camera for bottom maintenance - Page 2 - SailNet Community
 1Likes
post #11 of 20 Old 01-25-2013
I don't discuss my member
Fstbttms's Avatar
Re: Underwater camera for bottom maintenance
Originally Posted by sd1953 View Post
I looked through my files and found the bottom cleaning article, "Do it yourself Bottom Cleaning" by Carolyn Shearlock.
Do-It-Yourself Bottom Cleaning
That should get you to the article. It does assume that you will be in the water doing this job.
A quick glance at the article and the tools the author recommends is all this hull cleaner needs to know that she has zero idea about proper in-water hull cleaning procedures.
Fstbttms is offline
post #12 of 20 Old 01-25-2013
Fstbttms's Avatar
Originally Posted by Frogwatch View Post
Maybe combine the GoPro with some bright LEDs and mount it on a long stick with a pressure washer attachment. Then instead of diving to clean bottoms, you could do it from the dock
A pressure washer should never be used underwater on a painted surface. Or a fiberglass one.
Fstbttms is offline
post #13 of 20 Old 01-25-2013
Geoff54's Avatar
I was just looking for something else and bumped into this underwater camera/light with live video that attaches to a boat hook - not cheap but looks like the exact thing.
Underwater Submersible | Underwater Viewing System | Aquabotix
"The great thing about the internet is that you can quote anyone and no one will bother to check the source" - Aristotle
Geoff54 is offline
post #14 of 20 Old 01-25-2013
Familycruisers's Avatar
And only 80 bucks more than a GoPro that now has the capability to transmit to your cell, and has numerous mounting options.
Vency likes this.
S/V Never Land
Westerly Centaur
Familycruisers is offline
post #15 of 20 Old 01-25-2013
Geoff54's Avatar
Excuse me for passing along the information!
As I see it the weakness of the GOpro is the lack of lights.
Geoff54 is offline
post #16 of 20 Old 01-26-2013
Your excused, but why, did you fart or something?
Just an observation and that Go Pro is a neat piece of kit.
Wireless functionality alone, anyway, back to the thread already in progress.
S/V Never Land
Westerly Centaur
post #17 of 20 Old 01-27-2013
Frogwatch,
I have been using a USB camera for a couple of years. I put it in a clear plastic container (waterproof) and extended the USB cable with about 20' of CAT-5 cable. I have experimented with a couple of LED flashlights for illumination but want to have a more permanent solution by supplying power through the cable. The lighting has to be adjusted a bit to minimize glare. I use 1/2" plastic conduit with a couple of 45-degree elbows to reach the bottom of the boat (easy to set up when the boat is hauled for winter storage) and just plug it into my laptop. It's cheap (the camera was about $10) and especially nice to take a quick look if I think the propeller might have snagged something.
tibtib is offline
post #18 of 20 Old 01-27-2013
deltaten's Avatar
Send a message via Yahoo to deltaten
Now, just ta get a camera that will clean it fer ya!
deltaten is offline
post #19 of 20 Old 01-27-2013
Dirt Free
boatpoker's Avatar
This is the best underwater camera I have seen for only $59.99
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
post #20 of 20 Old 01-27-2013
Fstbttms's Avatar
Fstbttms is offline
Using GoPro camera to inspect bottom/prop melody1204 Maintenance/How-to Videos 15 05-04-2015 07:05 PM
Bottom Paint Maintenance sailorduff Gear & Maintenance 7 09-16-2011 11:07 AM
Gadget: Airmar Underwater Camera artbyjody Gear & Maintenance 0 06-11-2008 01:27 PM
Canon Combines Top-Tier Tech and Classic Camera Design into Line Leading 10-Megapixel PowerShot G7 Digital Camera (FinanzNachrichten) NewsReader News Feeds 0 09-14-2006 06:15 AM
Underwater Profiles Tom Wood Buying a Boat Articles 0 01-24-2002 07:00 PM
