plexiglass or lexan - SailNet Community
post #1 of 2 Old 04-22-2004 Thread Starter
plexiglass or lexan
My overhead hatches are extremely scratched and I am ready to replace them. What are the merits of plexiglass over lexan or visa versa and is there an ideal sealant material to set them into my bronze hatch frames. Thanks
prussell is offline
post #2 of 2 Old 04-23-2004
plexiglass or lexan
A good primer:
“Synthetic Rubber-Based Adhesive Sealants”
From "The Practical Sailor Library - Volume IV - Do-It-Yourself Improvement Projects"
<url>http://cruisenews.net/db/page.php?site_id=2219</url>
There are numerous adhesive that are formulated for bonding Polycarbonates* & Acrylics* (glazing) to FRG.
*Lexan is (GE) polycarbonate, which is much more shatter resistant and harder than Acrylic.
*Acrylic Plexiglas, Lucite, Acrylite, and Perspex are polyacrylate. Acrylic is more scratch resistant than Lexan.
Whichever adhesive/bedding compound you select should be:
Chemically compatible /w glazing & substrate
UV Stable
Mold Resistant
and have whatever mechanical characteristics your specific application may require (gap filling, sandable/paintable, etc). A window/glazing shop is often a good source.
Most plastic parts will have residual mold release or wax on the surface; before bonding, this should be removed with a suitable solvent-such as Acetone or Methyl Ethyl Ketone (if necessary)- and then abraded, lightly, with a medium-grit emery paper.
In all cases, parts should be bonded as soon as possible after pre-treatment. If bonding must be delayed, I recommend that the parts be covered with a light tissue paper and stored in a non-contaminating, dry atmosphere.
HTH
Gord
GordMay is offline
Proper adhesive/sealer for Lexan RoadTool Gear & Maintenance 33 12-06-2013 07:22 PM
plexiglass or lexan prussell Gear & Maintenance 2 04-22-2004 07:59 PM
lexan maestro Gear & Maintenance 4 02-19-2004 08:45 PM
Rebedding leaking lexan ports jhoover3468 General Discussion (sailing related) 12 12-01-2003 09:17 PM
