thru-hulls without seacocks? - SailNet Community
post #1 of 9 Old 01-26-2013 Thread Starter
robbieland's Avatar
I'm replacing the thru-hull fittings and hoses on recently purchased victoria 18. It seems odd to me there just through hulls and no seacocks or cutoff valves from hull below to deck. Am I missing something in understanding this concept such as scientific dynamics that water will not travel up below water line to deck? I'm planning to dock the boat in a lake for few months, but obviously wanted to make sure I'm doing this correctly. Thanks for any advice
robbieland is offline
post #2 of 9 Old 01-26-2013
Re: thru-hulls without seacocks?
The water will self level at balance, of course.. The only way it will end up in the cockpit is if the cockpit sole ends up below the water line ( sometimes when heeled, or too many people on board)
The main issue with no seacock is the inability to close things off in the event of a problem. I believe that some Pearsons were built that way too.
Faster is offline
post #3 of 9 Old 01-26-2013
Stu Jackson's Avatar
Are those the cockpit drain lines? Some builders did that to avoid "dummies" closing them and flooding the cockpit and sinking the boat. Still, not a good idea, but just make sure you have double hose clamps on the underwater end of the hose.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #4 of 9 Old 01-26-2013 Thread Starter
robbieland's Avatar
Yes. They were initially without the double clamp and plastic thru hulls, I'm changing out for bronze and doubling the clamps. Thanks for the info/reassurance.
post #5 of 9 Old 01-26-2013
Jiminri's Avatar
Well, that clears a few things up. When my Nonsuch 30 was surveyed, the surveyor commented that the cockpit drains did not have seacocks on the thru hulls. I did not realize that some (most??) boats do. She said that was ok, but to make sure they are double clamped (they are) and have wooden plugs available in case of an emergency. But maybe I should see about swapping out for seacocks.
Jiminri is offline
post #6 of 9 Old 01-26-2013
tommays's Avatar
I owned a new Victoria 18 in 1981 and i do not recall anything below the waterline JUST the drains ?
It was left in the water with NO bilge pump and never got a DROP inside
A J24 has two fairly scary above the waterline drains also which would certainly sink the boat IF a hose failed and the sink drain would let in MUCHO water if the hose failed
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #7 of 9 Old 01-27-2013
Senior Junior Member
Murphy, as in Murphy's Law, loves to hear people say, especially on a boat, "I've never had a problem in the X number of years I've had my boat."
If you have through-hull below the waterline or below the heeled waterline make sure you have an ABYC/UL 1121 seacock.
Watercolor is offline
post #8 of 9 Old 01-27-2013
tommays's Avatar
Except for on the Victoria 18 and the J24 there NOT what people are assuming its is much more like self bailing powerboat suppers
I also sail on a 1970 C&C 35 MARK I with and equally silly setup and if you DID have valves and closed them the cockpit would fill and FLOOD the cabin the FIRST time it RAINED
Tommays
Northport NY
tommays is offline
post #9 of 9 Old 01-27-2013
Senior Moment Member
SloopJonB's Avatar
I've seen metal boats where the cockpit drains were simply tubing welded between the cockpit sole and the hull - very slick since they both eliminated seacocks, hoses, clamps etc. and added some rigidity to the boat.
One could probably do it with glass tubes in a glass boat but I'd want the tubes to be THICK.
SloopJonB is online now
Basics of Seacocks, Thru-Hulls, Valves Jaywalker Gear & Maintenance 16 03-16-2016 07:24 PM
Of thru-hulls and seacocks... utchuckd Gear & Maintenance 3 08-06-2012 04:48 PM
Replacing seacocks and through hulls. davewild Gear & Maintenance 8 03-04-2010 11:48 AM
Thu Hulls vs Seacocks BluewaterBruce Gear & Maintenance 13 08-28-2008 11:40 AM
New thru-hulls/seacocks ereuter Gear & Maintenance 27 05-07-2007 06:31 PM
