crazed port lights - SailNet Community
post #1 of 4 Old 04-24-2004 Thread Starter
crazed port lights
The port lights on my 1992 C+C 34/36 plus are badly crazed. Does anyone have experience in the removal and re-installation process?
PerryD19 "Hurlyburly"
PerryD19 is offline
post #2 of 4 Old 04-25-2004
paulk's Avatar
crazed port lights
Before going through the major hassle of replacing your portlights, try a simple fix: rubbing compound. UV rays degrade the plastic''s outer surface over time, causing haze and crazing. Regular automobile rubbing compound applied on the outside of the ports and polished off (as per the directions on the can) should clear them up pretty well. It might take 30 minutes, instead of the 3 weeks it would take you to change the lights yourself. (The three weeks does not include the additional six weeks it will take to find and fix the leaks in the newly installed portlights. ) Sunlight will continue to degrade the plastic, of course, but you should be able to buy yourself a few more years before needing to take things all apart. After all, the boat''s only twelve years old!
paulk is offline
post #3 of 4 Old 04-26-2004
crazed port lights
303 aerospace protectant will protect against that sort of crazing, fyi.
hamiam is offline
post #4 of 4 Old 04-26-2004 Thread Starter
crazed port lights
Thanks for the advice on the quick fix. I''ll give it a try. Besides I''m anxious to go sailing! PerryD19
PerryD19 is offline
Require Navigation lights HeartofGold Seamanship & Navigation 10 03-20-2006 07:46 PM
Minimizing Taxes; Hailing Port kc_cmc Boat Review and Purchase Forum 14 03-04-2004 07:40 PM
Electronic charting without a serial port... WHOOSH Gear & Maintenance 21 04-21-2003 07:02 PM
Anchor Lights Dzedzej Seamanship & Navigation 5 02-27-2003 07:55 PM
proper navigation lights?? waltersofbayport Seamanship & Navigation 3 06-18-2001 06:12 PM
