Drilling into mast & boom - Page 2 - SailNet Community
 4Likes
post #11 of 13 Old 01-28-2013
HANUMAN
RobGallagher's Avatar
Re: Drilling into mast & boom
Isn't there a rule about using cutting oil on aluminium when drilling... or not oiling... Can't remember if it's one of the other. And you want to drill at low speeds I think. There must be a machinist here who can give some advice.
HANUMAN
'88 C&C 30 MKII
NOANK, CT
RobGallagher is offline
post #12 of 13 Old 01-28-2013
Wish I never found SN!
SimonV's Avatar
As far as I know very slow speed, cutting grease and a Cobolt drill bit, is for Stainless. Aluminum HS drill bit and a speed what you are comfy with.
Simon
I miss my boat
Brisbane
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #13 of 13 Old 01-28-2013
Hello all,
agree with Simon V, drilling into aluminium just requires a sharp drill and relatively high speed drill. One trick when marking out is to tape the area in masking tape for two reasons, 1) when marking out you can easily mark the tape as opposed to the alumimium and it will not rub off any where near as easily. 2) when drilling the tape will actually assist you set the drill in the correct spot to drill, using a metal centre punch to identify the area to drill then use a small drill to ensure the centre it located correctly. This will ensure that each and every hole lines up (hopefully)
ozsailer is offline
Mast & boom MSO sailor General Discussion (sailing related) 8 01-18-2013 06:31 AM
C&C 32 boom and mast cec513 Gear & Maintenance 3 01-13-2013 11:31 PM
Mast Drilling Stillraining Gear & Maintenance 55 10-15-2010 10:43 AM
mast vs boom 9407 Gear & Maintenance 13 05-25-2010 04:51 PM
Drilling in Mast johnferrell Gear & Maintenance 8 03-20-2009 05:44 PM
