Which winch? - Page 4 - SailNet Community
 7Likes
post #31 of 39 Old 01-28-2013
SchockT's Avatar
Re: Which winch?
I just replaced my primary winches last season. Winches CAN wear out if they are not maintained. On Lewmar winches the stainless pawls are held in sockets machined into the aluminum drum casting. Those sockets get loose and ovalled out, and eventually they can no longer keep the pawl captive and aligned. The end result is a catastrophic winch failure. If this happens at the wrong time it can also result in a broken arm for the person grinding!
I did my homework on all the winches before I settled on Andersens. There were comparable to the others in price but i got full SS rather than aluminum. The Andersen4 ribbed drum design gives superior grip compared to others, it is easier on the ropes because it doesn't rely on an abrasive surface for grip. Even if they are a bit more expensive, they are well worth it!
steve77 and SloopJonB like this.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #32 of 39 Old 01-28-2013 Thread Starter
steve77's Avatar
Re: Which winch?
Thanks for the feedback. I think after reading the comments here I am starting to lean towards the Andersens if I do decide to go with new ones. The place here in MA (Rigging Only) lists them for cheaper than Lewmars or Harkens at W Marine or Defender. Makes it very tempting.
steve77 is offline
post #33 of 39 Old 01-28-2013
Seņor Member
PorFin's Avatar
Re: Which winch?
Steve,
+1 for making any decisions only after you've had a chance to take the winches apart to see what you are actually facing. Of all the machines on a boat, winches are probably the longest lived.
FWIW: I've found that Lewmar pawls and springs fit my Barients just fine. The bearings OTOH are another matter.
As to making them all from the same manufacturer, I know you realize that this is purely cosmetic. A TrueValue hardware screwdriver looks funny among a drawer full of Craftsman tools, but it works just as well.
Since the boat is new to you, you may want to belay any major spending decisions until you've had a chance to sail it a bit. It would suck to have sunk all that money into replacing something that is otherwise serviceable, only to find that it would have been put to better use on something that has a better ROI.
BTW: Congrats on the new boat!
SloopJonB likes this.
________
'85 BYB Vagabond 39
PorFin is offline
post #34 of 39 Old 01-28-2013
Senior Moment Member
SloopJonB's Avatar
Re: Which winch?
Porfin - did you find the Lewmar pawls to be an exact replacement in your Barients? I found they fit the pivot just right but there was just enough difference in their length that they had to be replaced in pairs or the slightly longer one would bear all the load.
SloopJonB is online now
post #35 of 39 Old 01-28-2013
SloopJonB's Avatar
Re: Which winch?
One more reason to only get bronze or S/S winches.
post #36 of 39 Old 01-28-2013
Seņor Member
PorFin's Avatar
Re: Which winch?
SJB,
To be honest I didn't notice the difference in length -- my approach was that since they work as a pair, they should be replaced as a pair.
________
'85 BYB Vagabond 39
PorFin is offline
post #37 of 39 Old 01-28-2013
SloopJonB's Avatar
Re: Which winch?
SJB,
I'm cheaper than that. If it ain't broke, I don't fix it.
I replaced the broken one and when I reassembled it and spun it the pawls didn't sound right so I pulled it apart and looked closely - one pawl was just a couple of thou. shorter so the longer one was the only one engaging.
post #38 of 39 Old 01-28-2013
Seņor Member
PorFin's Avatar
Re: Which winch?
I bet your wife dreads the day you blow out one of your shoes...
________
'85 BYB Vagabond 39
PorFin is offline
post #39 of 39 Old 01-28-2013 Thread Starter
steve77's Avatar
Steve,
Thanks, I'm really looking forward to sailing it. Heck, I'm even looking forward to sanding and varnishing all the brightwork. I do realize that getting new winches would involve a bit of um, "vanity", but I'm ok with that. There are a few other upgrades and repairs I plan on doing that will involve some $$$ and that are a higher priority than new winches, so I won't be doing anything rash.
A lot of great feedback and suggestions in this thread and I appreciate them all. I think they will all come in useful regardless of what I do and when I do it. Many thanks to all who have responded.
steve77 is offline
WINCH 1 do I have. plz help arborjockey Gear & Maintenance 7 04-20-2012 12:35 PM
Winch handle in winch glassdad General Discussion (sailing related) 19 05-11-2011 05:10 PM
Which winch? Polypterus Gear & Maintenance 3 04-12-2010 08:24 PM
Winch Way? garycalvinsmith Gear & Maintenance 1 09-12-2006 08:06 AM
which winch?? maestro Racing 2 03-30-2004 01:47 AM
