Topside Paint - SailNet Community
post #1 of 6 Old 01-29-2013 Thread Starter
whughes's Avatar
Topside Paint
I'm thinking about re-painting the topsides of my CD-22 with a 2 part polyurethane; Interlux Perfection or Pettit EZ Poxy 2.
Any pros or cons for either one?
Thanks in advance.
Warren
whughes is offline
post #2 of 6 Old 01-29-2013
Re: Topside Paint
What were they painted with before? My understanding is you can't put 2 part on top of 1 part, or vice versa, at least not without a great deal of complex prep.
MarkSF is offline
post #3 of 6 Old 01-29-2013
Re: Topside Paint
I don't really think it matters too much which 2 part you choose to use.. some are more easily repairable than others, but beyond that the result will be mostly the same.
As SNer Tommays, and others, will tell you - it's 90% preparation that does the trick. As Mark notes, old paint may have to come off entirely. Over gelcoat is a different story but you should sand, prime, fair, fair, fair, then maybe paint for best results.
Do you have access to spray equipment or do you plan to roll & tip? We had reasonable results with a compact HVLP spray setup such as used for bathtub refinishing.
Faster is offline
post #4 of 6 Old 01-29-2013
tommays's Avatar
Re: Topside Paint
What are you starting out with as paint is a LAST RESORT when the gel-coat is beyond redemption
I had 1981 gel-coat still pretty close to perfect
my 1970 Cal 29 was a beyond that
Awlgrip and Perfection are COMPLETELY UNFORGIVING of any failure to follow ALL the directions completely
The big ONE is how much any moisture overnight destroys the gloss
In the fall of back when i was primed and i ran out of weather and had to WAIT UNTIL MAY to have the right humidity overnight
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #5 of 6 Old 01-29-2013
Re: Topside Paint
Tommays,
Is that sprayed or brushed? Just wondering. How simliar do you think it is to auto painting? In my previous life i went to school for automotive refinishing and worked several years in the industry. Someday i'd like to repaint my boat (hull). Spraying with Imron sounds good. Used it many, many moons ago. Somedays i wonder why some of the newer basecoat/clearcoat systems haven't spilled over to the boat world. The UV resistance is HUGE. Look how long a paint job lasts on a car nowadays verses 15 yrs ago. Amazing.
Sorry for hi jacking the thread a little.
I could see how you would want something very durable on deck. Hmm.. paint over paint. bad. You are right about prep. The more prep the better the paint job.
benesailor is offline
post #6 of 6 Old 01-29-2013
tommays's Avatar
Re: Topside Paint
Roll & Tip
The spray deal does not scale up well
I *build and paint a nice bicycle*
But your mixing *at 2:1:1 *for 4 oz of paint to spray a frame and your working with a SATA mini-jet
When your spraying *a boat 4 oz becomes gallons that have to be done NON-STOP and it gets really complex*
Tommays
Northport NY
tommays is offline
Seafevers topside paint tommays Cal 3 04-02-2013 06:19 PM
Help with topside paint repair malyea Gear & Maintenance 25 02-03-2013 11:27 AM
Non Skid topside paint? BreakAwayFL Gear & Maintenance 4 03-19-2012 10:00 PM
topside paint stevenm Boat Review and Purchase Forum 1 09-23-2002 10:00 AM
Topside Paint lifespan mrb2222 Gear & Maintenance 4 08-26-2002 06:44 PM
