The Head - SailNet Community
post #1 of 7 Old 04-25-2004 Thread Starter
The Head
I installed a head tank on my 32 last season. Used the best of everything. It works great except that for a few days after pump out I can smell that odor in the fore cabin, where the tank is installed. Any ideas?
Irwin32 is offline
post #2 of 7 Old 04-25-2004
paulk's Avatar
The Head
Sometimes the hoses absorb (and emit) odors from the head & tank. The solution is to replace them with non-absorbent ones. Also, have you tried using enzyme tablets or other treatments? Even after pumpout, there may still be redidue in the tank.
paulk is offline
post #3 of 7 Old 04-26-2004
The Head
goto http://boatbuilding.com/content/sanitation.html
Peggy is an expert in such problems and sorts out the facts from the fiction.
hamiam is offline
post #4 of 7 Old 04-28-2004 Thread Starter
The Head
The setup is brand new - hoses, tank and toilet.
Irwin32 is offline
post #5 of 7 Old 04-28-2004 Thread Starter
The Head
Peggy turned out to be a dead end.
Irwin32 is offline
post #6 of 7 Old 04-29-2004
The Head
Check your tank vent(s). You need good ventilation (2 vents, for cross-vent is best).
GordMay is offline
post #7 of 7 Old 05-01-2004
The Head
If the vents are all clear, consider using a head additive like candure or similar that accellerates breaking down organic material.
Failing that look at the BILGEBUSTER. We had the same problem, installed one and the problem was gone within 12 hours.
splitmind is offline
head manual Belgiansailor Gear & Maintenance 2 10-23-2015 11:50 AM
Vacuflush toilet, head. toilets Myblueheaven General Discussion (sailing related) 18 03-25-2013 05:47 PM
Control Head fix for Merriman Steering System tdp Gear & Maintenance 1 06-09-2011 03:00 PM
Head installation Irwin32 Gear & Maintenance 4 03-20-2003 12:23 PM
Head Problems bootsy1962 General Discussion (sailing related) 3 02-19-2002 07:26 PM
