-   -   Dorade boxes??? (http://www.sailnet.com/forums/gear-maintenance/96207-dorade-boxes.html)
blutoyz 01-30-2013 11:41 AM
Dorade boxes???
Ahoy....Only 48 days till' Spring...LOL
I have these two lexan deadlights (for lack of a better term) on my deck and was wondering if it would be worth installing a couple of dorade boxes with vents?
One of them is leaking so I will have to mess with them anyway but I would like opinions on functionality and if you think that I will clutter my deck on this small 27 footer.
http://i28.photobucket.com/albums/c223/BLUToyz/deck.jpg
tommays 01-30-2013 11:44 AM
Re: Dorade boxes???
I like mine and can post a picture tonight
Faster 01-30-2013 11:51 AM
Re: Dorade boxes???
Properly done, dorades can be really helpful on the ventilation front. We have molded in versions that work well except sometimes we can get quite a cold draft down from the windward facing cowl (our dorades are just above the aft ends of the settees)
http://i213.photobucket.com/albums/c...wcanvas002.jpg
Your location is somewhat problematic in that if you place them where your deadlights are they will be prone to catching jibsheets mid-tack and so should have some proper guards installed as well, adding to the cost of the change.
svHyLyte 01-30-2013 11:58 AM
Re: Dorade boxes???
Three inch day/night solar vents could prove very useful. They will of course limit the amount of light you can get through the dead lights if that is a consideration although you can "off-center" the vents somewhat. We have been using solar vents since the late 80's and have been very glad to have them.
FWIW...
blutoyz 01-30-2013 12:04 PM
Re: Dorade boxes???
Good point on the sheet catching...That is exactly why I posted, another set of eyes can save lots o' trouble later.
Thanks
Faster 01-30-2013 12:42 PM
Re: Dorade boxes???
Thanks
The guards typically look like this.. if the two are close enough together you might get away with a single guard structure if that doesn't cause other issues:
http://i213.photobucket.com/albums/c...5/file-147.jpg
blutoyz 01-30-2013 01:14 PM
Re: Dorade boxes???
No offense to those that have the these guards but on my small boat it just wouldn't look right.
tommays 01-30-2013 01:18 PM
Re: Dorade boxes???
The vents will last about 3 minutes with guards as i have enough problems with PEOPLE wacking them with guards :)
The sails aree fine
blutoyz 02-01-2013 08:59 AM
Re: Dorade boxes???
The sails aree fine
I think that saw a shot of your boat on another thread and I could hardly notice the guards. If you have a pic of the deck I would appreciate it if you could throw it up.
You have no problem with you sheets getting fouled on a tack?
Thanks
tommays 02-01-2013 09:22 PM
Re: Dorade boxes???
