Transmission output flange fell off Yanmar 2QM15 - Theories re: why? - Page 4 - SailNet Community
 2Likes
post #31 of 34 Old 02-12-2013 Thread Starter
JeffBurright's Avatar
Re: Transmission output flange fell off Yanmar 2QM15 - Theories re: why?
As an update, we received a replacement flange and locking nut from a friend who came to visit us from back home. We also decided to replace the engine mounts, as one of the adjustment bolts spun in its rubber housing when I tried to adjust the alignment.
As we all suspected, the new flange had much longer teeth and gripped the transmission output spline much better. There was no wiggle between the spline and the new coupling, so Gary's point about the spline being made of harder metal than the coupling (and remaining undamaged) appears to be true. The old flange must have just been reamed out by the spline due to engine misalignment.
To complete the repair, first I installed the new coupling and spun on the locking nut. On the advice of a local mechanic I used a flat punch and a hammer to get the last little bit of torque on the locking nut, then used a cold chisel to calk it in and lock it in place.
Next was to replace the engine mounts. I borrowed a car jack and lifted one corner of the engine at a time, sliding out the old mount and sliding in the new. This was a relatively painless process that took an afternoon.
Finally came realignment of the engine. There are other guides out there on how to do this properly, but suffice to say that when I first checked the alignment on the old engine mounts, the transmission output coupling was probably 1/4 to 1/2 inch below the prop shaft coupling. This would explain the vibration issues, the worn cutless bearing, and the eventual failure of the coupling. The vibration and noise should have been a clue a long time ago, but it took separating the two coupling parts to actually see how bad it was.
After completing repair, we took the old girl out in the bay for a sail. Immediately we could feel and hear the difference. Our feet felt barely a buzz through the cockpit floor. The prop shaft swished smoothly straight through the packing gland where before it was a vibrating blur. With the new mounts, the motion of the engine itself had changed from a battering shake to a calm rumble. As we motored along, the cat took to perching with his belly on the companionway stairs like he was snuggled up to a purring mother.
If you haven't checked your alignment recently, I highly recommend it.
PS - On that last trip, I did notice more vibration transmitted through the tiller than we remembered from before. I feel pretty confident about my alignment job, so could there be some other reason why the rudder has more vibration?
Faster likes this.
JeffBurright is offline
post #32 of 34 Old 02-12-2013
Great news... I wonder if the vibration you feel now in the tiller was always there, but overshadowed by all the other 'bump and rumble' you had before....
Faster is offline
post #33 of 34 Old 02-13-2013
Learning the HARD way...
eherlihy's Avatar
It is possible that the vibration that you now feel is from the new flange, and the old transmission shaft not mating perfectly. The new flange surface should be exactly perpendicular to the axis of rotation of the flange. This isn't likely to happen unless you can get the transmission and the flange to a good machine shop.
However, you might try the following simple fix to lessen the issue; remove the bolts holding the prop shaft coupling to the transmission output flange. Align the holes so that the next hole on the propeller shaft aligns with any given hole on the transmission output shaft (move it one hole). Put everything back together, and try it out.
If the characteristic of the vibration changes, you confirmed my theory. If it changes for the better, keep it there. If it changes for the worse, try aligning a different set of holes.
eherlihy is offline
post #34 of 34 Old 02-13-2013
Odd that no one has mentioned the use of a feeler gauge. Sort of useful in determining parallel flange faces after centering the coupling. This can be done after you know that the coupling and prop shaft are fitted properly( this may need the machine shop lathe )
Capt Len is offline
Tags
flange , hurth , output coupling , transmission , yanmar
Yanmar 2QM15 sundownersc Diesel 11 02-09-2012 10:21 AM
shifting issue transmission of 2QM15 Yanmar LiaSophia Diesel 2 08-05-2011 11:04 PM
Help with yanmar 2qm15 stuck transmission Waterman28 Diesel 2 05-05-2011 03:44 AM
2qm15 motor mounts and transmission alignment kegendron S2 2 03-08-2011 08:24 PM
Male pilot coupling optional for output flange? Flugeler Gear & Maintenance 1 07-31-2009 10:16 PM
