Installing a Boom Brake - Page 2 - SailNet Community
 1Likes
post #11 of 11 Old 02-05-2013
Re: Installing a Boom Brake
I attached a wichard boom brake using the alternative method recommended by the manufacturer, that is 2 x fixed lines attached to the base of the shrouds, I added a u bolt on boom just aft of the vang with a block attached to this and the line from this going back to a winch and block. So far I've found it to be very satisfactory. The tension on the line has to be adjusted according to the wind strength, light winds you don't want it too tight otherwise the boom won't go across.
srah1953 is offline
Dutchman boom brake Lidgard29 Seamanship & Navigation 6 10-21-2009 09:52 AM
Boom brake or preventer?? RandyBC General Discussion (sailing related) 14 04-29-2008 10:17 AM
Boom Brake/sizing roywmoss Gear & Maintenance 3 08-29-2007 04:56 PM
Scott Boom Brake teshannon Gear & Maintenance 14 08-22-2007 11:44 AM
Boom Brake KIKO Gear & Maintenance 0 03-17-2002 04:39 PM
