Inflatable tender for 30' sailboat - Page 3 - SailNet Community
post #21 of 34 Old 02-04-2013
bljones's Avatar
Re: Inflatable tender for 30' sailboat
Originally Posted by CalypsoP35 View Post
BL,
I've been bottom painting my inflatable for years with rubberized dinghy bottom paint. (I think I'm using a Petit product.) I have no interest is scrubbing it down regularly. I paint it in the spring, put it in the water and don't think about again until I pull it in late October. Once the season starts all I want to do is sail and/or relax on the boat, I try to minimize my in season maintenance. I never break it down and put it on deck, if i want to take it with us, I tow it.
I can see your point if you never haul your dink on deck.
It's 5 o'clock somewhere:
bljones is offline
post #22 of 34 Old 02-04-2013
Much to learn...
Capt-T's Avatar
Send a message via Skype™ to Capt-T
Those of you with the Garhauer motor lift... is this easy to store when not in use? I'm assuming there must me some type of mounting hardware on the transom with a collapsable davit arm that stores when not in use. Is this correct? If so, does the arm completely remove from the mounting hardware? or just fold up in place? or something else... pics earn you bonus points!!
Capt-T is offline
post #23 of 34 Old 02-04-2013
CalypsoP35's Avatar
I'm not sure who makes my motor lift, but on mine the arm folds folds down and the total storage space is basically two 2" diameter tubes side by side and the line in a bag. Requires very little storge space. The only hardware on deck is a stability ball on the deck and a ring on the rail.
Calypso
Pearson P-35 #481
CalypsoP35 is offline
post #24 of 34 Old 02-05-2013 Thread Starter
Sootydan's Avatar
Thank you for all your input. I'll be keeping it in the water next to my boat at a marina and I'll tow it when I go on trips. I just have to decide which size I need now. Saturn has a 7.6', 8.6' and 9.6 footer. I was going for the 8.6 or 9.6. I wont be carrying alot of weight in it , two people max usually and not alot of gear. I have a 5HP Mercury OB that can use a portable gas tank If i want to. Saturn SD260 is 8.6 , selling for $775.00 + $59.00 shipping, probably a good size. I don't know anything about the Saturn brand.
Sootydan is offline
post #25 of 34 Old 02-05-2013
no longer reading SailNet
Alex W's Avatar
Keeping it in the water all the time is pretty hard on the dinghy. Why not put it on the dock (with a rack that holds it vertical) when you don't have it in use? Otherwise you'll probably be hauled it out every couple of months to clean it anyway. If you aren't using it regularly (weekly?) the dinghy will last much much longer if you keep it deflated and put away when not in use. I bet a PVC dinghy will last only a few years if kept out in the sun, but go for decades if mostly kept rolled up and only inflated when it use. It takes me about 5 minutes to unpack and inflate my 7'7" Zodiac Zoom.
You can get an 8'6" Zodiac Zoom from Defender for less money than the Saturn that you are looking at. If you aren't in a rush it'll be even cheaper when they have their big spring sale (usually in April?). The Zoom is imported by Zodiac from China and made from PVC, so not comparable to their higher end boats, but it is probably at least as good as the Saturn and the company has wider representation so parts and warranty issues should be easier. The Saturn is also a PVC boat.
7'7" is plenty for two people and not much gear in my experience, 8'6" should be more than enough.
Alex W is offline
post #26 of 34 Old 02-05-2013
Rhys05's Avatar
Are you set on needing a motor for your dinghy? I'm considering something like this inflatable kayak for our 26' boat. Cheap, light, no motor to worry about, etc.
http://www.amazon.com/Sea-Eagle-SE370-Inflatable-Package/dp/B001ASRVDK/ref=wl_it_dp_o_pC_S_nC?ie=UTF8&colid=27JBSXRABXFES&coliid=IGZ7545Q92KL6
Rhys05 is offline
post #27 of 34 Old 02-05-2013
4arch's Avatar
We faced the same question a couple of years ago and ended up going with a West Marine RU-3 slat floor. It's 8'-6" and that has worked out to be a good size for the two of us and for our 30' boat. We can inflate it on top of the companionway hatch and store it on top of the foredeck upside down. It's light enough to launch easily from the deck and when we're finished with it we can roll it up into the size of a large duffel bag and throw it in the quarter berth. With the slat floor it doesn't track well under power and doesn't row well at all, but the ability to store it so compactly below decks usually makes that a reasonable compromise. If we had a larger boat we probably would have gone a little larger and with the high pressure air floor but we didn't want the tender to be unmanageable. Capacity wise, the 8'-6" would be tight with 3 adults even though it's rated for that capacity but it's fine for 2.
s/v Spindrift
Beneteau Oceanis 400
formerly Lippincott 30
4arch is offline
post #28 of 34 Old 02-05-2013
bljones's Avatar
A kayak is great to paddle, but hard to get into from a swim ladder and has little load capacity with two aboard.
bljones is offline
post #29 of 34 Old 02-05-2013
Rhys05's Avatar
True. I guess it really depends on what you need the tender for, if you need to go get groceries and transport lots of stuff a long distance, you need the dinghy type with a motor, whereas if you (like us) just want to be able to paddle in to the beach/island/whatever from the anchored boat to hang out, then the kayak will work fine. It also probably helps that the transom on our boat is pretty low.
Rhys05 is offline
post #30 of 34 Old 02-05-2013
chef2sail's Avatar
I dont have a picture as its rarely set up. I have the Garhauer radar pole with detachable engine hoist. On the pole are two permanent ring clamps about 2 feet apart with slots on the side of the clamps for a verticle pin,
The detachable hoists 2 arms with the verticle pins at the ends of them, unfold like accordian till reaching the 2 feet length and slide down into the slots and are locked in by a pin ring, The arms are then attached to the bar with a 6:1 purchase with a carniner on the end
Open link and click on the bottom radar pole picture to enlarge, Detachable hoist stores in a small bag about the size of a 3 foot piece of 2X4
Garhauer Marine Hardware -5537120
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
Inflatable tenders vs tender inflatables Windkiller Gear & Maintenance 40 07-11-2012 04:25 PM
Inflatable Tender (Rubber Duck Inflatables) krozet Gear & Maintenance 7 08-31-2010 09:29 AM
Inflatable tender for the Whitsundays deandavis1 Gear & Maintenance 3 06-12-2010 08:52 AM
Inflatable tender emergency inflation device mariner3302 Gear & Maintenance 2 10-20-2006 08:01 PM
Tender: inflatable or folding? Lucian General Discussion (sailing related) 10 09-02-2002 12:38 AM
