rusting stainless - Page 3 - SailNet Community
 4Likes
post #21 of 23 Old 03-21-2013
Re: rusting stainless
Bar keepers friend and a lot of elbow grease helps keep the bloom at bay.
Lazy D is offline
post #22 of 23 Old 03-22-2013
overbored's Avatar
Spotless Stainless it will clean it up and passivate in one step Home - Spotless Stainless Removes Rust, Protects Stainless Steel
all stainless steel will rust because it contains Iron. the surface should be mechanically or electrically polished and then passivated. the polishing helps allow the surface to dry and not hold moisture. the passivation removes the surface iron molecules, and then it is rinsed with DI water and then allowed to air dry which forms chromium oxide on the surface this helps protect the stainless steel from corrosion.
Never polish after passivation or you will remove the protective oxide and it will rust
"GOLD RUSH" PRINDLE 16
overbored is offline
post #23 of 23 Old 03-22-2013
NON member
AE28's Avatar
Some of the REALLY cheap grades of 200 Series from India are also non-magnetic.
AE28 is offline
Rusting Anchor Chain...What to do? ncapener Gear & Maintenance 2 04-22-2012 09:30 PM
FW cooling heat exchanger mounts rusting? downeast450 Atomic 4 1 07-21-2011 06:47 AM
Stainless chain plate rusting L124C Gear & Maintenance 11 03-30-2009 03:36 AM
Quadrant rusting winethief Gear & Maintenance 3 08-04-2008 09:34 PM
Rusting keel? Jotun Boat Review and Purchase Forum 6 11-26-2006 07:06 PM
