Old 02-03-2013
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Re: Wd40
I've heard that 1/2 ATF and 1/2 acetone is a fabulous penetrant but haven't needed any since I learned about it. I've seen claims that it will even free up stainless fasteners locked into aluminium parts.
I, myself, personally intend to continue being outspoken, opinionated, intolerant of all fanatics, fools and ignoramuses, deeply suspicious of all those who have "found the answer" and on my bad days, downright rude.
  #12
Old 02-03-2013
Minnewaska will become famous soon enough
Re: Wd40
I've not hear that, but you sure wouldn't want it to spill on anything. Especially anything painted or plastic.
Jeanneau 54DS
  #13
Old 02-03-2013
SloopJonB's Avatar
Re: Wd40
Yes, you'd need to be neat with it but I wish I knew about it when I disassembled my 40 year old mast. Might have saved me a couple of hammers.
  #14
Old 02-03-2013
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Re: Wd40
Do any of you lube experts use McLube sailcoat for your mast tracks, blocks etc?
MCLUBE Sailkote Dry Lubricant at West Marine
Everybody has one:
  #15
Old 02-03-2013
transmitterdan is on a distinguished road
Re: Wd40
Yes, McLube works great on sail track. It dries quickly and doesn't make a mess. I put it on the main sail slides about once a month and they always go up and down the track effortlessly.
I found another unexpected use for it recently when I had to pull and re-bed a chain plate. The plate would come up only about 1 inch and then stick in the 5200 bedding. I sprayed McLube from below and coated the bottom half. Once the lubed part moved up into the bedding it slid right through. No oily mess. This is good stuff and useful on boats.
Transmitterdan
1995 Valiant 42
  #16
Old 02-04-2013
kellysails's Avatar
Puget Sound Pounder
kellysails is on a distinguished road
Re: Wd40
+1 on MCLUBE, I use it on my Strong Track system, really works and no mess.
  #17
Old 02-04-2013
Philzy3985's Avatar
Philzy3985 is on a distinguished road
Re: Wd40
+1 on McLube for the sail track.
Had a pro rigger tell me never to use WD40 on anything. He said there is something better for whatever you're using it on (engine or rigging) and he gave me a can of T9. That seems pretty good for unlocking stuck nuts/bolts and stays on as a lubricant as well. Just his opinion, I haven't done much else research.
1985 Catalina 30 Std Rig "A Cenoura"
itsACenoura.tumblr.com
  #18
Old 02-04-2013
chucklesR's Avatar
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
Re: Wd40
T9 as a lubricate is the #1 thing I reach for.
Read, laugh, learn, or just enjoy
You may post attachments
You may edit your posts
SEO by vBSEO 3.6.1
