Wd40 - SailNet Community
post #1 of 18 Old 02-03-2013 Thread Starter
PAULCR1's Avatar
Wd40
Hi All,
Just bought a S2 11, first boat, and would like to know what, if anything, I shouldn't use WD40 on? Will cause any damage to lines, fiberglass, etc.? I really like the freeing up properties of WD40 but don't want to over do it. Thanks for any input.
Theodore Roosevelt said “In any situation, the best thing you can do is the right thing; the next best thing you can do is the wrong thing; the worst thing you can do is nothing.”
PAULCR1 is offline
post #2 of 18 Old 02-03-2013
FSMike's Avatar
Re: Wd40
WD-40 is designed to be applied to metal. Getting it on lines, fiberglass, etc., can stain and attract dirt.
There are better products on the market for freeing up rusty objects. Try PB Blaster aka Power Blast.
Sail Fast Live Slow
36' Solaris Sunstar catamaran
FSMike is offline
post #3 of 18 Old 02-03-2013
bigdogandy's Avatar
Dock
Re: Wd40
+1 on the PB Blaster....ditch the WD and get a can of PB. Wrap a rag around the parts you are spraying to keep the overspray from getting on everything else. Let it sit for a few minutes and you will be amazed at what it will free up.
And only use it to free up rusted metal...there are much better things to use for lubricating and freeing up other things (insert joke here____________).
Andy
Key Largo
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is online now
post #4 of 18 Old 02-03-2013
Re: Wd40
As far as freeing up frozen parts, I recently read where Liquid Wrench is even better than PB Blaster.
Catalina 34
chuck53 is offline
post #5 of 18 Old 02-03-2013
deltaten's Avatar
Send a message via Yahoo to deltaten
Re: Wd40
The "wd" in WD-40's name stands for "water displacement. the 40 means it is/was the 40th formula..or attempt. Makes me wonder if it's soooo good; why did it take 40 tries!
For all that, it works as intended; but not for much else. It is a modified fish oil in a specific carrier. It *will* dry up and turn waxy if left on a surface; usually to end up gumming the works.
It will not prevent rust, release stuck bolts or lubricate anything better than the proper solution for a specific problem. Mostly just that it's handy and universal. There are better/newer products for each issue; but none are usually to hand when ya need 'em.
deltaten is offline
post #6 of 18 Old 02-03-2013
Re: Wd40
You're right about how WD40 got it's name but I take issue on "if it's so good, why did it take 40 tries"?
Product development is usually a very time consuming, lengthy process. I have nothing to back this up, but I'm willing to bet $20 that 40 tries is way on the short side in the world of product development.
Catalina 34
chuck53 is offline
post #7 of 18 Old 02-03-2013
Re: Wd40
WD40 is great stuff and I always have a can aboard. However, it isn't a universal lube or solvent and you do not want to get it on fabric.
Jeanneau 54DS
Minnewaska is offline
post #8 of 18 Old 02-03-2013
Re: Wd40
I think most people are under the impression that WD-40 will lubricate moving parts. It will but only briefly. It is meant to "displace moisture" (WD). It does lubricate for a bit but then actually dries out the parts you use it on. It works, like many other materials on the market today, to free up moving parts/bolts/nuts etc. In order to "lubricate" things after freeing them up, you must use a,,,, wait for it,,,, lubricating oil/material. On a lot of things around a boat I like to follow up with a light oil like 3 in one oil or one of the synthetic lubricants.
bogdog is offline
post #9 of 18 Old 02-03-2013
jrophoff's Avatar
Re: Wd40
The best stuff I found for breaking things loose is kroil penetrating oil. I bought off amazon. It even lubricates too.
jrophoff is offline
post #10 of 18 Old 02-03-2013
Senior Moment Member
SloopJonB's Avatar
Re: Wd40
Edison took over 10,000 attempts to get the light bulb working.
WD40 is mostly just kerosene.
SloopJonB is online now
