Like Tree2Likes
  #1
Old 02-04-2013
PAULCR1's Avatar
Grumpy Cat
PAULCR1 is on a distinguished road
Question Lettering Removal
Just bought an older boat and am trying to remove the old name. I bought a heat gun and got the old vinyl lettering off and used "Sticker Off" to remove the adhesive but can still plainlly see the embossed lettering. This lettering is the original boat name and has probably been there for 30 years. I used the heat gun as much as I dared without setting the boat on fire. Any suggestions or first hand real world experience how to get these off? Thanks in advance.
Theodore Roosevelt said “In any situation, the best thing you can do is the right thing; the next best thing you can do is the wrong thing; the worst thing you can do is nothing.”
  #2
Old 02-04-2013
Lake Superior Sailor's Avatar
Lake Superior Sailor is on a distinguished road
Re: Lettering Removal
Is it the finish that is faded around the lettering that you see?...Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
  #3
Old 02-04-2013
PAULCR1's Avatar
Grumpy Cat
It's not that the finish is faded. There is a very definite lift in the edges where the lettering was, almost as if there is still a piece of cellophane still there.
  #4
Old 02-04-2013
Consider a razor blade & maybe wet sanding?..Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
  #5
Old 02-04-2013
chucklesR's Avatar
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
That 'embossed' letting is the result of the gel coat under lettering not being oxidized and flaking off as the exposed gelcoat was.
You remove it with 600-1200 grit wet sand paper, no other way.
dacap06 and paul323 like this.
Read, laugh, learn, or just enjoy
  #6
Old 02-04-2013
PAULCR1's Avatar
Grumpy Cat
Thanks guys for your input. I did try a plastic razor and sanding with 800-1200 sandpaper was my next option. Just wanted to be lazy and avoid it. Thanks again.
  #7
Old 02-04-2013
chucklesR's Avatar
the avoidance method is to ignore it.
I found out the hard way on my Hunter. Going from "swallow" to "wallow" to "allow" to "allo" then a massive weekend of sanding
  #8
Old 02-04-2013
djodenda's Avatar
djodenda will become famous soon enough djodenda will become famous soon enough
It will probably not be noticeable as long as you quit looking for it...
I'm with Chuckles.. ignore it.
David
1987 CS 36 Merlin "Kyrie"
  #9
Old 02-04-2013
chucklesR's Avatar
We'll see how well I follow that piece of advise when I rename my Irwin.
  #10
Old 02-04-2013
Silvio's Avatar
Battered and Bruised
Silvio is on a distinguished road
As long as it is gelcoat and not paint you can spray easy off oven cleaner on it. let it sit 15b minutes or so an wipe it off. if the gel coat yellows simply wash it down with vinegar then rinse with water.
SV S.S.R.I
It's my happy pill
You may post attachments
You may edit your posts
Boat Lettering jray4888 General Discussion (sailing related) 23 07-13-2011 11:41 PM
Vinyl Lettering Removal from Awlgrip ACKward Gear & Maintenance 11 07-18-2010 09:41 PM
Lettering paint removal Bobio Gear & Maintenance 5 07-14-2010 06:54 AM
on line lettering xort Gear & Maintenance 14 05-31-2008 06:48 PM
ISO help for 380 - lettering size pamnospam Catalina 2 05-15-2007 11:06 AM
SEO by vBSEO 3.6.1
