Location of water tank breather pipe - SailNet Community
 1Likes
post #1 of 21 Old 02-04-2013 Thread Starter
My Bristol 31.1s fresh water tanks are vented with a loop that goes from the lower tank (in the bilge) up to deck level, then down again and ends a foot above the cabin sole, inside the area under the galley sink.
It's quite a good arrangement, except that when I fill the water tanks, any excess soaks the area under the galley sink - and the damp is starting to rot the sole.
Any reason why they didn't extend the pipe all the way into the bilge? I'm thinking of doing this.
Configuration is : 1 tank under the V berth, second tank lower down in the bilge. The bow tank drains into the bilge tank. Lower tank is vented.
MarkSF is offline
post #2 of 21 Old 02-04-2013
Re: Location of water tank breather pipe
Cut the hose up near deck level & put a 1 way plastic check valve on it.
I'm not happy unless I'm complaining about something.
I'm having a very good day!
misfits is offline
post #3 of 21 Old 02-04-2013 Thread Starter
Which way is the one way valve? Surely I'll either be able to fill the tanks, or empty them, but not both?
MarkSF is offline
post #4 of 21 Old 02-04-2013
fallard's Avatar
If you use misfits' check valve, you won't be able to completely fill your tanks.
fallard is offline
post #5 of 21 Old 02-04-2013 Thread Starter
It seems we are both thinking along the same lines...
MarkSF is offline
post #6 of 21 Old 02-04-2013
You should be all set. Most tank connections for filling are at the top of the tank. The fill hose itself is something like 1 1/4", 1 1/2". The vent hose is not to bleed air out of the tank, it's so you do not create a vacuum when drawing water off the tank. If the vent hose was for bleeding air out of the tank during filling it would be the same diameter as the fill.
That's the way plumbing works, just my .02
misfits is offline
post #7 of 21 Old 02-04-2013 Thread Starter
There is only a 1/2" ID hose between the bow tank and the bilge tank. The filler is in the bow tank. I think that's why the lower tank has a vent.
MarkSF is offline
post #8 of 21 Old 02-04-2013
fallard's Avatar
The vents on my boats are at the end of 1/2" hose and the fill hose is 1 1/2". There is no check valve. They work fine with a full stream when filling. So, no, the vent hose does not have to be the same size as the fill.
If you have a check valve to keep water from overflowing your vent line when filling, then, as you fill the tank, you will trap air that becomes compressed. You will stop filling the tank when the pressure of the compressed air equals the pressure of the fill stream. This is based on observation--not conjecture--and the volume of trapped air can be significant. This is easy enough for MarkSF to verify by plugging his vent and then trying to fill the empty tank(s).
Bottom line: The vent is there to facilitate both fill and drain.
An easy fix might be extending the vent hose temporarily to drain into the galley sink when you are filling your tanks. You could coil it up the added vent hose and stow it after filling the tanks.
MarkSF likes this.
fallard is offline
post #9 of 21 Old 02-04-2013 Thread Starter
I like the idea of a separate hose, I'll try it!
MarkSF is offline
post #10 of 21 Old 02-04-2013
Mark SF,
I went back thru the OP. Fallard is correct, the fashion in which your tanks are plumbed, a check valve will not work.
I wouldn't extend the vent into the bilge due to cross contamination issues.
It could be like installing a faucet for drinking water in your toilet.
misfits is offline
Fresh water tank vent location options josrulz Gear & Maintenance 27 07-10-2014 04:37 PM
additional potable water tank location izzy1554 Columbia & Coronado 1 06-27-2013 12:26 PM
additional potable water tank location izzy1554 Gear & Maintenance 10 08-08-2012 07:12 PM
PVC Pipe for a holding tank? kwaltersmi Gear & Maintenance 25 11-11-2010 04:21 PM
Poly holding tank pipe thread seal surftom Gear & Maintenance 9 06-23-2008 02:55 PM
