Galley Sink Drain Dilemma - SailNet Community
post #1 of 6 Old 02-05-2013 Thread Starter
When I purchased my boat (Spirit 28), both the galley and sink drains were plumbed to the through hulls via a mashup of household plumbing, adapters, hoses, and glue. I didn't much like the looks of all that, so I've since been in search of an elegant way to connect a sink drain to a hose.
I finally solved the head sink (found a drain fitting designed for a 1 1/4 hole, with a 3/4" hose barb), but I've been unable to find a solution for my galley sink, which has a 3 1/2" hole (same size as a household kitchen sink).
Problem is that household kitchen sink drains have a 1 1/2" threaded connection, and I haven't been able to find a 1" hose barb connector that fits a 1 1/2" connection (1 1/4" connectors are commonplace).
Here are the possible solutions, as I see it:
1. Find a fitting that has a 1" hose barb on one end, and a 1 1/2 threaded connector on the other.
2. Find a marine sink drain that fits a 3 1/2" drain hole, with a 1" hose barb.
3. Install a new sink with a 2 7/16 drain hole.
I'd prefer option 1 or 2 -- does such an animal exist, and if so, does anyone know of a source?
Rusty123 is offline
post #2 of 6 Old 02-05-2013
sunfish?junior?
Re: Galley Sink Drain Dilemma
Industial air hose fittings some are barbed SS. I do not have time tonight stay out of home deport Lowes and other home owner stores They are good for home supply. Gainger catolog or catapiller, John deere hydro fittings. oil refinery supply sorry got to go to sleep good luck , Lou
Lou452 is offline
post #3 of 6 Old 02-05-2013
mitiempo's Avatar
Because of the size jump you might have to use multiple fittings but it can be done.
Brian
mitiempo is offline
post #4 of 6 Old 02-05-2013
Stu Jackson's Avatar
Here's what someone else did:
http://www.c34.org/wiki/index.php?ti...ley_Sink_Drain
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #5 of 6 Old 02-05-2013
sunfish?junior?
Fergusons plumbing supply they are nation wide just checked. Swedgeloc will also be able to hook you up. Good day, Lou
Lou452 is offline
post #6 of 6 Old 02-06-2013 Thread Starter
I discovered that Skandvik makes an adapter to go from 1 1/2" to 1 1/4" threads. I just ordered one, hopefully it will do the trick.
Thanks for the tips!
Russ
Rusty123 is offline
How does a sink drain work? jarcher Gear & Maintenance 40 04-20-2016 10:23 AM
sink drain ? Southron Spirit North American Yachts 10 12-10-2012 03:06 PM
B30 Galley Sink bvermeer Islander 0 03-29-2009 12:23 PM
Parts for sink drain overholtzer S2 1 09-07-2007 05:07 PM
galley sink HeidiMills Gear & Maintenance 4 07-26-2001 09:13 PM
