Bimini Ideas - SailNet Community
post #1 of 7 Old 02-05-2013 Thread Starter
H2814D's Avatar
Bimini Ideas
Ok. So summer is coming and I sail on Lake Mead, Nevada (read 115 degrees F with lots of bright sun) and I want to attach a bimini to the boat. Here, though, is the issue: end of the boom main sheet and the traveler is attached inside the rear of the cockpit. If you look at my photo you can see what I am talking about. So how does one account for the clearance of the main sheet as it moves side to side with a bimini top up? Is the top designed with an opening of some type? I do not want to move the traveler anywhere else.
The boat is a 1979 Islander Bahama 30.
Anyone?...and thanks in advance for any helpful replies/pictures.
HD.
H2814D is offline
post #2 of 7 Old 02-05-2013
Rhys05's Avatar
Re: Bimini Ideas
Not much help to you, but I've been wondering the same thing about my boat, as the traveler is in the middle of the cockpit (well, really about 25% of the way from the back to the front) and the backstay is connected at the back of the cockpit too. I'm guessing that I'll have to go with something that only covers from the companionway to just forward of the traveler, and then either sit in the sun while hand steering or use the autopilot when I don't want to be in the sun.
Rhys05 is offline
post #3 of 7 Old 02-05-2013
Re: Bimini Ideas
You could use two smaller biminis with a slot between the two for the mainsheet. The trailing edge of the front shade needs to be curved to allow the mainsheet to run out. The rear bimini could have a curve to the leading edge to maximise the shade.
Kevin
Tallswede is offline
post #4 of 7 Old 02-05-2013
Barquito
Barquito's Avatar
Re: Bimini Ideas
Maybe use a boom tent while at anchor, and a wide brimmed hat while sailing.
Valiant 32
Barquito is offline
post #5 of 7 Old 02-05-2013
chef2sail's Avatar
Re: Bimini Ideas
The backstay. Our backstay also impacts the bimini so the back edge of the bimini has a fore to aft zipper installed midway across it . End stop on the forward portion is about 1/2 the distance in, There are two zipper pulls on it, one at the end stop halfway in pulls towartd the aft and closes the zipper till it runs into the backstay. The other zipper pull strats at the back edge of the zipper slit and closes the zipper pulling forward to the bacstay, Essentially you make a slip and put a zipper in it and pullit closed back to the backstay and forward to the backstay.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #6 of 7 Old 02-05-2013
Re: Bimini Ideas
Maybe talk to the local canvas shop that does biminis, dodgers, etc.
Seaduction is offline
post #7 of 7 Old 02-05-2013
Re: Bimini Ideas
Have you considered moving your boat to the British Columbia coast? Summer temperatures rarely exceed 65 deg. A good set of rain gear is all you need.
Neal
ncapener is offline
Solent Stay Ideas-Possible hairbrained ideas Joel H. General Discussion (sailing related) 39 01-26-2013 07:09 PM
Bimini top JUST MESSIN WITH IT North American Yachts 6 06-08-2012 04:16 PM
Bimini replacement ideas and opinions lans0012 Gear & Maintenance 25 08-03-2010 03:48 PM
To bimini or not to bimini that is the question davidpm General Discussion (sailing related) 16 09-14-2008 10:05 PM
