Suzuki DF 6 outboard motor fuel switch? - SailNet Community
post #1 of 5 Old 02-06-2013 Thread Starter
Hello, I recently purchased a Suzuki DF 6 outboard motor. It is a 2007 and has an internal gas tank as well as a fuel line connector for an external. There is a fuel switch underneath the head. I think I figured on and off but I'm wondering if there is a position on the switch that allows fuel to flow in from an external tank or will connecting up an external tank override or supplement the internal tank.
I cannot locate an operating manual so if you have a link to one, please let me know.
Thanks!
Phil Turner
pturner is offline
post #2 of 5 Old 02-10-2013
Dufour 27 Newb
Re: Suzuki DF 6 outboard motor fuel switch?
Hi! I do not think that there is a internal/external fuel selector - just the fuel on/off located under the lower engine cowling. Either way you don't really run the risk of getting stranded.
jaybeegee is offline
post #3 of 5 Old 03-03-2013 Thread Starter
If I hook up an external tank to the motor fuel fitting, will it automatically take in fuel while the motor is running? Does it do this at the same time that it uses fuel from the built in tank or does it automatically over ride the built in tank? I sure wish there were an operating manual for this motor. I purchased the generic repair manual for Suzuki's and I can't find anything on operating.
pturner is offline
post #4 of 5 Old 03-03-2013
Large Member
GMFL's Avatar
I believe that Tohatsu makes the Suzuki 6hp. (could be wrong) If so, maybe try tracking down a Tohatsu owners manual.
I have the Tohatsu 6hp with internal tank and will look at the manual when I get back from dinner tonight if it turns out they are the same.
Maybe someone else can confirm that for you???
GMFL is offline
post #5 of 5 Old 03-03-2013
Large Member
GMFL's Avatar
OH, jsut noticed this post is 3 weeks old, I'm guessing he figured it out.
GMFL is offline
Tags
suzuki 6 hp fuel switch
Brand new Honda 5HP Outboard won't start - should I switch mfg? FishDragon Outboard 24 08-16-2014 03:18 PM
best outboard motor? Kiltmadoc General Discussion (sailing related) 11 05-28-2011 03:07 PM
How do I re-attach the pull string on a Suzuki 2.5 HP outboard? n0w0rries Gear & Maintenance 5 01-17-2011 06:12 PM
Suzuki 9.9 1994 fuel line re-attachment Skipper Jer Gear & Maintenance 4 01-02-2010 09:33 PM
