mounting rod holder to fiberglass transome - SailNet Community
post #1 of 3 Old 02-07-2013 Thread Starter
I have a rib and the transome is fiberglass. I was considering mounting pole holders to it. How do you drill and seal the bolt holes?
jasonr575 is offline
post #2 of 3 Old 02-14-2013 Thread Starter
Re: mounting rod holder to fiberglass transome
Has anyone ever drilled through a fiberglass hull?
post #3 of 3 Old 02-14-2013
blutoyz's Avatar
If you want to mount rod holders that will never come loose you can drill right through and bolt with stainless hardware. Silicone on each side is smart to keep water from seeping into the transom core.
There is no real trick to it just measure twice and drill once
blutoyz is offline
wood transome plate for a rib jasonr575 Cruising & Liveaboard Forum 7 02-05-2013 02:12 PM
Hardware to transome fastening slimslowslider Cal 0 02-05-2009 06:59 PM
What boats around 25-30 feet have a transome cutout for an outboard? dataBoy Boat Review and Purchase Forum 13 08-28-2008 03:00 PM
Garmin 498 C Sounder Opinions ? Transome mounted Transducer? chuck711 Gear & Maintenance 2 01-14-2007 10:11 PM
Holder 20 Nickdude05 Boat Review and Purchase Forum 1 08-03-2003 02:10 AM
