Oil in exhaust? - Page 2 - SailNet Community
 5Likes
post #11 of 15 Old 02-11-2013 Thread Starter
Learning Fast
Re: Oil in exhaust?
Klem,
Great explanation! On a 2 day cruise we just got back from, I saw both smoke symptoms. Black when I tried higher revs and thin grey smoke at low revs. I'll look into cleaning something and get some help. The boat speed was fine & as anticipated at whatever RPM I tried, so any mud on the prop is long gone.
Outrageous is offline
post #12 of 15 Old 02-11-2013
celenoglu's Avatar
Re: Oil in exhaust?
oil in exhaust is generally from the oil cooler. Sea water cools the oil and because oil pressure is more than water pressure, oil passes to the cooling water and finally to exhaust.
celenoglu is offline
post #13 of 15 Old 02-11-2013
Re: Oil in exhaust?
Your diesel could use a decarbonization via the fuel tank and the crankcase oil. Improvements will be noticable quit soon after using "Seafoam", obtainable from any automotive store.
sony2000 is offline
post #14 of 15 Old 02-11-2013
Glad I found Sailnet
Bene505's Avatar
Re: Oil in exhaust?
Did you see oil on the water? If not, then you probably aren't exhausting oil.
Other than that, black smoke can mean barnicles on the prop. (At haul, out, I had 6 feet of line wrapped around the prop.)
I suggest you buy a mask, fins and a snorkle (and wetsuit). Like owning a Mast Climber, it pays for itself quickly.
Regards,
Bad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #15 of 15 Old 02-12-2013
Re: Oil in exhaust?
Have you always seen grey smoke at lower revs? If you haven't, check to make sure everything else is normal like engine operating temperature.
Have you always seen black smoke at the higher revs? A little bit of black smoke at high loads is perfectly normal on older diesel engines. They allowed them to overfuel a bit to get the horsepower rating up, the newer ones don't do this because of emissions. The only real downsides to it are it is worse for the environment, your mileage will be worse, and you can damage pistons and valves in extreme cases with high exhaust gas temperatures. If the black smoke is new and everything else being normal such as the boat speed versus the rpm, the first thing that I would look at is the air filter, a plugged filter will cause this.
klem is offline
Oil in my exhaust Coronado35 Diesel 5 05-31-2012 11:54 PM
Yanmar YSM-8 Exhaust ? rjg23 Diesel 7 08-11-2010 12:10 PM
Crystals in exhaust dhornsey Gear & Maintenance 5 03-24-2009 11:25 AM
Wet Exhaust Hose 1970Columbia34 Gear & Maintenance 1 03-09-2009 08:40 AM
Wax job and exhaust smoke grinfax Gear & Maintenance 3 10-26-2008 08:19 PM
