Tach - SailNet Community
post #1 of 10 Old 02-10-2013 Thread Starter
PAULCR1's Avatar
Tach
Just purchased a new, for us, 1983 S2 with a 35hp Universal. Haven't even had her out yet. Started the engine the other day and noticed that the tachometer was working. Opened the engine compartment and found a wire laying there. Pulled the control panel in the cockpit and saw that the same color wire ran to the back of the tach. I cannot find where the end in the engine compartment attaches to the alternator. Any incites???
Theodore Roosevelt said “In any situation, the best thing you can do is the right thing; the next best thing you can do is the wrong thing; the worst thing you can do is nothing.”
PAULCR1 is offline
post #2 of 10 Old 02-10-2013
Dufour 27 Newb
Re: Tach
Is there any label next to the connection on the tach sider ? You mentioned the tach works - does it have a light bulb on it and is it still working?
jaybeegee is offline
post #3 of 10 Old 02-10-2013
priscilla's Avatar
Re: Tach
PAULCRI The Universal operators manual will have a wiring diagram, Go to Westerbeke.com to download one. Universal 35 is a good engine.
Priscilla
priscilla is offline
post #4 of 10 Old 02-10-2013
Re: Tach
On a diesel it most likely was attached to the alternator tach post. If the alternator has been replaced with an aftermarket(GM single wire high output) it might not have had a tach post, as my replacement did not have. BUT, check the wiring diagram before assuming anything. You can always take the alternator to an automotive electronics rebuild shop and have a post added, don't know the cost though.
wescarroll is offline
post #5 of 10 Old 02-10-2013 Thread Starter
PAULCR1's Avatar
Re: Tach
The tach isn't working. I mis-typed my original question. That is my problem, I cannot find a 'tach' post on the alternator and after thinking, a unique experience, I cannot expect anyone to know what alternator is in here. Thanks all for your replies, I will muddle through.
PAULCR1 is offline
post #6 of 10 Old 02-10-2013
Re: Tach
Is it painted the same color as the engine? Also are there several wire running to it or just one.
post #7 of 10 Old 02-10-2013
Re: Tach
Wiring diagram for M-35 universal w/tach go here: .marinedieseldirect.com/catalogs/catalog_group.php?owner=mdd&page_ident=200145-54&model=M-35 / M-35A&manufacturer=Universal&title=Wiring Diagram&quant_position=&catalog=200145&printparts=200145&printservice=200155&printoperators=200157&comment1=
post #8 of 10 Old 02-10-2013
Re: Tach
Torrensen aka marine diesel direct may have even been the supplier of that engine to S-2. They have all the schematics on line. Also they have a great knowledgeable staff, a bit pricy but I have been happy with their service.
post #9 of 10 Old 02-11-2013 Thread Starter
PAULCR1's Avatar
Re: Tach
Thanks for all the help.
PAULCR1 is offline
post #10 of 10 Old 02-11-2013
chucklesR's Avatar
Re: Tach
Not all tach's take the signal off the alternator.
Some take it off the flywheel.
Check your manual.
chucklesR is offline
Replacing the Tach; Universal 5411 "Tiny Tach" jrhamp Diesel 3 10-23-2012 12:26 AM
I need a tach ekenna Electronics 0 03-09-2011 08:46 PM
desiel tach: Tiny-tach dreuge Diesel 5 04-30-2010 11:04 AM
Yanmar 1GM tach problem? mwrohde Gear & Maintenance 2 06-16-2008 10:38 AM
Yanmar Tach. billangiep Gear & Maintenance 4 09-21-2007 09:42 PM
