Re-wiring mast...What size wire? - SailNet Community
 1Likes
post #1 of 12 Old 02-11-2013 Thread Starter
rhr1956's Avatar
The mast is off. I'm replacing lights and wiring. The boat is 12 gauge wire throughout. I am adding an LED anchor light at the top. Do I need to run #12 wire for this light or can I go with something smaller?
This is the light.
rhr1956 is offline
post #2 of 12 Old 02-11-2013
Learning the HARD way...
eherlihy's Avatar
Re: Re-wiring mast...What size wire?
That is a 0.12 Amp load. AWG #12 should be fine (overkill).
Because this is a Nav. light, the maximum allowed voltage drop is 3%.
eherlihy is offline
post #3 of 12 Old 02-11-2013
美国华人, 帆船 教授及输送
Oh Yeah.... way overkill. May be to consider redo the VHF cable, overkill is better in this case.
Fine Print:
I am old school. Integrity is to do the right thing even when no one is watching.
rockDAWG is offline
post #4 of 12 Old 02-11-2013
If I was wiring my own mast, I'd run an NMEA 2000 cable up there - in case you ever want to put a new wind instrument in.
MarkSF is offline
post #5 of 12 Old 02-11-2013
overbored's Avatar
to calculate the wire size you need wire length. my Led anchor light has 110 feet of #18 gauge. 100 feet of #18 is good for 1.5 amps. remember you have wire going up and back so the length of the mast times 2
"GOLD RUSH" PRINDLE 16
overbored is offline
post #6 of 12 Old 02-11-2013 Thread Starter
rhr1956's Avatar
I was curious about how much amp draw the light would create. Where did you see the 0.12 amp load number?
rhr1956 is offline
post #7 of 12 Old 02-11-2013
overbored's Avatar
the ad says it draws 1 watt so at 12 volts it would be P=IE or .083 amps
post #8 of 12 Old 02-11-2013
Maine Sail's Avatar
Keep in mind that the minimum wire size under ABYC standards for an application such as nav lights is 16GA regardless of the voltage drop.
MarkSF likes this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #9 of 12 Old 02-11-2013
chucklesR's Avatar
So then jerk some 14 gauge up there and in 20 years with ABYC changes it's standards you are still good
chucklesR is offline
post #10 of 12 Old 02-11-2013
tommays's Avatar
I used a piece of 16/5 round in a conduit and i made a hole at the steaming/deck-light exit 1/2 way up
The 16/5 and the coax cable was a tight fit in 3/4 pvc BUT never any noise
Then opened up a bit of the jacket so i could pull 3 wires out at the steaming/deck-light exit and ran the other two up top to the anchor light
The round seals much better with a cable clam and all the connections are below deck in a terminal box
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
Fusing to the size of the wire.... MedSailor Electrical Systems 6 10-05-2012 03:02 PM
Q: Standing rig wire size ulferlingsson Gear & Maintenance 1 06-11-2010 10:17 AM
110 wiring light switch without wire nuts? MedSailor Gear & Maintenance 23 12-22-2009 11:17 PM
Bonding wire size? sunfishin Electrical Systems 7 01-18-2009 09:25 AM
Windlass Wire Size 1970Columbia34 Gear & Maintenance 3 01-01-2007 08:05 AM
