Harken MkIV or Furlex 200s - Page 2 - SailNet Community
 1Likes
post #11 of 17 Old 02-13-2013
overbored's Avatar
Re: Harken MkIV or Furlex 200s
Could correct it being low with a toggle assembly and a few inch shorter headstay
I disagree with the thin plastic description. Harken is generally known for superior products. It appears yours is not installed correctly if you keep having the same problem
As far as the jam. And it happens to all furlers at some time. Which is easier to correct and fix....an open body drum or one which is closed
Raising it up will make the problem worse the top of the drum hits on the bow pulpit . its a Colgate 26 design flaw
"GOLD RUSH" PRINDLE 16
overbored is offline
post #12 of 17 Old 02-13-2013
ASA and PSIA Instructor
...I disagree with the thin plastic description. Harken is generally known for superior products. It appears yours is not installed correctly if you keep having the same problem
True, Harken makes generally great products, but FWIW, the top of this furler is a plastic disc with a thin lip subject to breaking. Or at least all six examples I have personally used have had this characteristic, and all broke..
Yes, the problem appears due to the Colgate install, but I'd bet you'll get the same result by lowering the spinnaker pole on the unit.
As to jamming, the Furlex never jammed provided the line lead was correct. I do not believe in ten years I ever removed its cover due to a jam. Hands down, a better unit by far.
sailingfool is offline
post #13 of 17 Old 02-13-2013
We have the Harken Cruising furler (similar to MKIV but single groove and fatter foil) and the only issue we've had is occasionally, for reason's I've not yet been able to nail down, the furling line escapes the drum cage and locks itself, effectively 'jamming' the furler. It's only happened during sailing, never part way through a furl or unfurl. Requires a trip forward to straighten out. I suspect it happens at the end of an unfurl with too much slack in the furler line.
Other than that (and regretting not going for the full MKIV after all) the only beef is the crappy, slippery furling line supplied with the unit.
Faster is offline
post #14 of 17 Old 02-13-2013
chef2sail's Avatar
They have changed the line in the last two years. Keeping pressure when unfurling is important to prevent a jam as is cleating off the furling line once it is pulled out. That will help as we had the same issues.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #15 of 17 Old 02-13-2013
... the furling line escapes the drum cage and locks itself, effectively 'jamming' the furler. It's only happened during sailing, never part way through a furl or unfurl. Requires a trip forward to straighten out. I suspect it happens at the end of an unfurl with too much slack in the furler line...
Faster, I have also assumed that to be the reason for Harken jams, the issue with part of the top being broken, is that the unit will consistently jam if any slack is permitted while unfurling.
post #16 of 17 Old 02-13-2013
Maine Sail's Avatar
If I agreed with this I would have purchased a second Furlex.. The cost was the exact same or within $30.00 to me (head stay included).
Our Harken has performed flawlessly. It reefs the sail better than the Furlex did, and the little plastic bearing race cover on the top swivel has not failed on me yearly like it did on the 200S...
Our plastic cover plate over the drum has had zero issues so I suspect the proximity of the bow pulpit to the furler drum is probably not a Harken issue... I also race on a boat with a MK-IV and it too has performed flawlessly..
Both are excellent units but I would go for a third Harken over the Furlex if I needed another furler... I also like the Schaefer but it does not reef as well and is more money than Furlex or Harken..
I think all the furlers from the big four are excellent. Schaefer, Furlex, Harken and Pro-Furl. I've owned all of them at one point or another plus a Hood Sea Furl and an old Hyde Stream Stay. Our current Harken replaced the Hyde Stream Stay..
chef2sail likes this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #17 of 17 Old 02-21-2013 Thread Starter
Smile Re: Harken MkIV or Furlex 200s
We decided to go with the Harkin MK IV. From reading many posts on the net and the feedback on this forum, it seems that the Furlex Nd Harken are both excellent quality. The installed price for the Harken with a new forestay and turnbuckle was $50 less the the Furlex (which comes with a new forestay). it came own to who was doing the install. The Harken dealer I have dealt with in the past (he re-rigged a Contessa 26 for us) and all the shop does is rigging. The Furlex dealer rigs new boats for the dealers and installs electronics, heaters, etc. I'm sure both would do quality work but I know the Harken does and the quality of the installation is what seems to make the biggest difference for furler satisfaction. Thanks to everyone who offerred advice.
Starbuck is offline
furlex mentalrevenge General Discussion (sailing related) 1 03-20-2012 07:54 PM
Schaefer CF700 vs Harken MKIV 0 fiatracer163 General Discussion (sailing related) 7 12-04-2011 08:48 PM
Furlex 200S Disassembly for transport Tailwheel Gear & Maintenance 3 06-03-2011 10:17 AM
Question about furling 200s Eleanna Gear & Maintenance 4 10-10-2007 08:00 PM
furlex furler Loualfr Gear & Maintenance 3 09-19-2007 11:09 PM
