Opinions/Reviews of CLIPPER Wind Instrument - Please !! - SailNet Community
post #1 of 3 Old 02-12-2013 Thread Starter
Does anyone have an opinion of the UK-made CLIPPER wind system (the masthead and the instrument) with regard to its use on a 22' sailboat ??
Thanks Essemm65
Essemm65 is offline
post #2 of 3 Old 02-13-2013
Re: Opinions/Reviews of CLIPPER Wind Instrument - Please !!
I have one (just the masthead unit so I can't comment on the display)... It appears flimsy, and the tail of mine was broken off in the box. Rather than return it to the UK, I glued it back on with some 3M 4200. Surprisingly, it has survived two hurricanes/tropical storms (New York area) since then.
There is no indication of how to align the masthead unit... I took care to align it in the most logical orientation, but the resulting wind data was off by about 120 degrees. This seems to be by design, and calibration must carried out in the display unit. (The masthead unit can also be calibrated by crossing two of the wires with the wind directly ahead, but that would have to be redone every time power is shut off.) Luckily, the Simrad display unit I am using is also able to compensate for this.
I think for a simple install it is probably fine if it helps you save a bunch on money. In my case, I wanted a masthead unit that output NMEA data directly, and this fit the bill. The calibration issues were a hassle, though, and when I have to replace it I will look at other products.
Pearson 33-2
Western Long Island Sound
davester is offline
post #3 of 3 Old 02-14-2013
Simrad make an NMEA 2000 masthead unit, which I'm using with the IS40 display. I didn't even have to calibrate it, it was spot on from the start. Very impressed so far. I think the masthead unit is made by B&G and sold by Simrad.
MarkSF is offline
CLIPPER Wind system - opinions ?? Essemm65 General Discussion (sailing related) 0 02-11-2013 09:56 PM
Datamarine Corinthian instrument opinions? thekeip Gear & Maintenance 5 10-19-2009 08:11 PM
wind instrument kms Gear & Maintenance 10 04-16-2008 09:21 PM
ST 60 Wind Instrument tommyt Gear & Maintenance 11 05-03-2007 11:44 PM
I''m looking for Sailing reviews/opinions for Gulfstar 60 andy woodruff Boat Review and Purchase Forum 0 01-31-2003 07:37 AM
