Old 02-15-2013
BillA98272 is on a distinguished road
Newbie looking at buying a sailboat with questions.
I looking into a Cal29 sailboat. It has been on the hard for a year and seller says it needs bottom paint. I m in the Seattle area, what is a ballpark figure to have that done?
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
  #2
Old 02-15-2013
jasenj1 is on a distinguished road
Re: Newbie looking at buying a sailboat with questions.
I think should ask this over in the Boat Review & Purchase sub-forum. Although the question is really about the cost of bottom painting, so maybe it does fit here.
  #3
Old 02-15-2013
capttb is on a distinguished road
About $1200 in S. Calif. area including haul and launch using 2 coats Petit Trinidad with a third at the waterline and leading edges. Many paints require being splashed (launched) within 24 hrs. of application. The paint used can make a large difference in price.
  #4
Old 02-15-2013
Alex W's Avatar
Alex W is on a distinguished road
Welcome to CSR Marine | CSR Marine has the pricing schedule for a popular local yard (that I used a couple of months ago). The other boat yards charge about the same. Including hauling, power washing, and two coats of a moderate cost paint I'd expect to pay around $1500. My 29' boat (pretty similar size too) took a little over 1-1/2 gallons to do two coats.
This is an ongoing cost that you'll expect to redo every 2-3 years on salt water (or more often if you use cheaper paint).
1986 Pearson 28-2 "Elena"
frequent crew/prior owner on Catalina 25 "Lutra"
Shilshole Marina, Seattle, Puget Sound, WA, USA
  #5
Old 02-15-2013
overbored's Avatar
overbored is on a distinguished road
you could also just launch and have a diver clean the bottom once a month for around $60 a month. you are in cold water so not much growth per month. gets you in the water for a lot less and then decide when to haul and paint. you may find other reasons to haul after you have it for awhile
"FULL TILT" SOVEREL 33
"GOLD RUSH" PRINDLE 16
  #6
Old 02-15-2013
Alex W's Avatar
Not if the boat has soft paint. There is a $10,000 fine for cleaning boat bottoms with abalative paint in WA state.
  #7
Old 02-15-2013
jimgo's Avatar
Asleep at the wheel
jimgo is on a distinguished road
Are you doing the work yourself, or will you have someone else paint for you? If you're thinking DIY, does the marina allow that? A gallon of bottom paint is about $130-$200. I haven't done bottom paint yet, so I can't tell you whether you'll need one coat or two. Since she's already out of the water, that makes things a little easier, but you'll want to touch up the areas under the jack stands before she's dropped in the water. Most marinas are pretty good about letting you do that once the boat is on the travel lift.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
  #8
Old 02-15-2013
Is it a roll on application or does it need to be sprayed? I am new to sailboats, I have a 20 ft power boat and it goes back on the trailer after each use so I do t have experience with bottom paints. Thanks everyone for the info I'm learning....
  #9
Old 02-15-2013
Oh also I'm dive certified as well...
  #10
Old 02-15-2013
Barquito's Avatar
Barquito
Barquito is on a distinguished road
If there is no other bottom repairs needed, you just scuff the bottom with a sander, and roll it on. Goes pretty fast. Paint the spots where the stands touch while the boat is on the travelift. You need to make sure the paint you are putting on is compatable with the old paint. You also need to check locally with what kind of paint works for your area. I'm a bit if a DIYster. Can't imagine paying someone to paint the bottom.
Bristol 27
Cirque
You may post attachments
You may edit your posts
Newbie with questions Peachstarfishing Chartering 1 04-21-2011 07:24 PM
Noob questions about buying a first Sailboat Polypterus Learning to Sail 17 06-10-2010 12:44 PM
Questions from a newbie. tausap Learning to Sail 29 06-25-2008 11:04 PM
Right of Way questions from a newbie mrsadm General Discussion (sailing related) 20 05-30-2008 03:34 PM
Newbie here with a few questions! Goodfreak General Discussion (sailing related) 4 12-07-2002 02:44 PM
SEO by vBSEO 3.6.1
