Yikes! Mooring System Failure - Page 3 - SailNet Community
 4Likes
post #21 of 24 Old 02-18-2013
blutoyz's Avatar
Re: Yikes! Mooring System Failure
In Warwick Cove we have semi-annual inspections required for moorings.
blutoyz is offline
post #22 of 24 Old 02-18-2013
Maine Sail's Avatar
Originally Posted by RobGallagher View Post
How hard is the bottom? My mooring must be inspected every 3 yrs, but, I've had a diver jet my mooring into the bottom so that it's completely under the mud.
The diver is also a third generation marina owner and swears that getting the mooring gear under the mud not only is better holding but that the iron rusts slower under the muck.
You have a good mooring guy that KNOWS a mooring needs to be set in order to work! They won't allow "jetting" around here as it stirs up too much silt and with 1400+ moorings.........They can get away with it for ACOE permitted work such as docks etc. but not for moorings. Some local mooring guys, the good ones, will "screw" them by running the barge in circles for the initial set at least enough to bury the bell. Our bottom is pretty soft on top but quickly turns into a hard blackish clay / goo..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #23 of 24 Old 02-18-2013
What ever you do; do not! I repeat, do not buy Chinese swivels.
Why?
because they're cast, not forged.
Dick
Flybyknight is offline
post #24 of 24 Old 02-18-2013
HANUMAN
RobGallagher's Avatar
Why?
Dick
They make all sorts of swivels in China; cast, forged, stainless, etc. Don't buy from unscrupulous suppliers and importers.
Iphones are made in China as are Iphonies that will last a week. Those factories in China build exactly what they are contracted to build.
Ritchard likes this.
HANUMAN
'88 C&C 30 MKII
NOANK, CT
RobGallagher is offline
Tags
chain , corrosion , mooring , shackle
Yanmar 2GM Winterization System Failure aloneinthewoods Diesel 3 09-06-2012 01:59 PM
Hazlett Mooring System question DoubleEnder General Discussion (sailing related) 0 11-09-2011 03:57 PM
Duarte Marine Makes Mooring Easy, Debuts First Single-Handed Mooring System - PR Web NewsReader News Feeds 1 10-06-2011 01:58 PM
New Mooring system jfranta Gear & Maintenance 2 05-07-2005 10:26 PM
Salt Water Cooling System failure. rclampitt Gear & Maintenance 4 07-28-2002 09:26 PM
