Winch Handle-Type Deck Fills - Where to Buy? - SailNet Community
post #1 of 7 Old 02-16-2013 Thread Starter
Maine Member
BELLATRIX1965's Avatar
Greetings all:
Have looked without success for a place to purchase winch handle-type (star) stainless steel caps for deck fills. Hood Yacht Systems claims to carry some (H6546-10), but I'm stumped where to turn. The ideal would be to simply replace the SS cap on my 1-1/2" hose DIESEL fill with a winch-handle type, but that may be asking too much?? May have to purchase the whole assembly? Thoughts??
BELLATRIX1965 is offline
post #2 of 7 Old 02-16-2013
Geoff54's Avatar
Re: Winch Handle-Type Deck Fills - Where to Buy?
I ignored this at first because I thought someone might have an actual answer but as no one replied I’ll tell you what I know.
These are much more common in Europe. The star type fills on Beneteau, Jeanneau etc. are made by Amiot. You can get replacement caps but I think you will find that they are metric thread and only fit Amiot fills. Vetus, Plastimo and several others also make star cap fills but I suspect you will find the same thing. Catalina Direct has color coded caps in plastic that work with the fills that were used on some Catalinas but I have no idea if they would work for you – might be worth a phone call. BTW stainless fills with color coded plastic caps seems to be the trend and in the U.K. at least, the usually term is “deck filler” – might help in a search.
Hope that’s of some help – Good luck.
"The great thing about the internet is that you can quote anyone and no one will bother to check the source" - Aristotle
Geoff54 is offline
post #3 of 7 Old 02-17-2013
overbored's Avatar
mako manufacturing makes some Mako Manufacturing 30402 Diesel Deck Fill 2" With Star Cap - Poco Marine
"GOLD RUSH" PRINDLE 16
overbored is online now
post #4 of 7 Old 02-17-2013
Geoff54's Avatar
Originally Posted by overbored View Post
That's not a winch handle star - it only has six points.
Geoff54 is offline
post #5 of 7 Old 02-17-2013 Thread Starter
Maine Member
Geoff:
Thanks for the guidance - and good observation on that "star" unit (good luck getting a winch handle into that one!). I was aware of the Amiot units, and will probably wind up going in that direction. My goal is to simplify and eliminate the need for deck key (spanner) wrenches. In addition, the winch handle - type adds (somewhat) to security (you can't open them with a screwdriver) without the need for specialized locking caps and keys.
post #6 of 7 Old 02-17-2013
Glad I found Sailnet
Bene505's Avatar
Call Beneteau customer service here in the U.S.
I'm in the process of replacing all my aluminum ones with stainless steel. (After 13 years, the aluminum ones get dificult to open.)
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is online now
post #7 of 7 Old 09-10-2015
I realize this is several years after the fact... but I found the winch style SS 1 1/2" Deck Fills in Diesel, Water and Waste available from Hood Yachts/Pompanette in FL. Current price as of September 2015 is $59.00 plus s/h. They also carry the 2" versions in Diesel, Water and Waste. They are different than the Amiot fills as far as the number of points in the star, but will at least be a similar replacement to other fills on the boat. Rig Rite in Rhode Island carries the Amiot, but at $189 from Rig Rite, unless you have the extra $$$ and want an exact brand and visual match, the fills from Hood Yachts/Pompanette are a realistic choice.
Slhky is offline
Gulfstar deck fills Harmon Gear & Maintenance 2 05-16-2012 05:02 PM
Gulfstar deck fills Harmon Gulfstar 0 05-16-2012 04:22 PM
Looking for an old winch handle j1brady Gear & Maintenance 22 10-01-2010 08:37 PM
winch handle marthajewel Gear & Maintenance 7 02-25-2009 10:57 AM
Keeping deck fills seperate Irwin32 Seamanship & Navigation 5 06-09-2006 10:00 PM
