Old 02-17-2013
Bene505's Avatar
Glad I found Sailnet
Bene505 will become famous soon enough Bene505 will become famous soon enough
(Saved by CO detector overvoltage beeping) -- Gel cell charge voltage settings?
Any opinions on this?
Background: We have a Solar Boost 3024i solar charge controller that I installed on our 170 watts of solar panels.
Yesterday while working on the boat, the CO detector went off. I was a little apprehensive until I read the top of the detector where it said that the slow blinking light means over/under voltage. Quickly looking at the Victron battery monitor, I saw the voltage at 15v and current at 3.86 amps. Not sure if that current was hurting our 330 amp-hour Gel cell bank, but seeing 15 volts was scary.
It turns out that I had the internal microswitch set for monthly equalize. I must have gotten the on-off direction confused. So I took the opportuniy to review the other settings. Here's what I have it set for:
charge voltage 14.4v
charge time: 2 hours
float voltage 13.2
This means that the solar panels will charge the batteries until they hit 14.4 volts for 2 hours. Then it will lower the voltage to 13.2 hours. (Of course, when the sun goes down, the charging stops.)
Any opinions on whether those are the right settings?
I can change the settings up or down in 0.2 volt increments. (If I get a separate device that programs the controller, I can be more precise. But for now, it's 0.2 volt increments.)
Regards,
Brad
Fun fact #2484: In my avatar, that's DavidPM at the helm of my boat.
  #2
Old 02-17-2013
Maine Sail's Avatar
Re: (Saved by CO detector overvoltage beeping) -- Gel cell charge voltage settings?
Brad,
Here's some advice for those with solar controllers that have auto equalize...
TURN IT OFF!!!!
As for GEL batteries (most are Sonnenschein or Deka/East Penn) absorption should be about 14.1V. Deka has recently upped this "allowable" voltage on their GEL batteries but when I see properly charged GEL batteries going 8 to 12 years I have to assume that they really like 14.1V and the people who invented the technology, Sonnenschein, knew what they were talking about when they advised 14.1V...
My concern with this new Deka charging voltage allowance is that is to "accommodate" potential buyers with "dumb" chargers and not in the best interest of longevity, which is where GEL's really win..
On your float voltage gels actually float (Sonnenschein & Deka) at higher than one would assume. They like to be floated at 13.6V to 13.8V with 13.8V being preferred...
I would highly recommend the IPN ProRemote especially with GEL or AGM batteries...
______
-Maine Sail / CS-36T
  #3
Old 02-18-2013
Bene505's Avatar
Thanks Maine! Now I have another reason to buy you a beer sometime.
I'll immediately increase the float voltage to 13.8 and decrease the charge voltage to 14.2. And I'm putting the IPN ProRemote is on my list of things to get.
Regards,
Brad
You may post attachments
You may edit your posts
Saved by CO detector -- Gel cell charge voltage settings? Bene505 Gear & Maintenance 0 02-17-2013 02:59 PM
Where do you go for a solar, motion detector? kb3pwc Gear & Maintenance 0 05-20-2012 09:40 PM
Not getting enough charge voltage. simple72 Electrical Systems 9 09-16-2009 01:26 AM
Open cell vs closed cell foam jarcher Gear & Maintenance 2 11-07-2008 07:54 PM
Radar Detector wind_magic Gear & Maintenance 4 07-02-2007 07:15 AM
SEO by vBSEO 3.6.1
