Sizing a spinnaker pole - SailNet Community
post #1 of 7 Old 02-18-2013 Thread Starter
Remember you're a womble
PaulinVictoria's Avatar
So the J measurement on my boat is 10'6", would a pole 9'4" work? I know they are usually chosen to be "around" the same as the J, but how close is still "around"?
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #2 of 7 Old 02-18-2013
Re: Sizing a spinnaker pole
Poles are generally at least J length... often slightly longer despite the rating penalty one would take.
Problem with a short pole is that in light air when you are sailing pole down (esp if the butt end is not on a track) the end of the pole and the tack of the spoinnaker end up inside the headstay and if you're reaching the sail is 'wrapped' across the stay.
This leaves the possibility of the pole coming up on the wrong side of the forestay, and you can imagine what that might to to the sail if the crew on the pole lift is heads down and doesn't notice what's going on. With a proper length pole it always stays on the weather side of the forestay, giving you the projection you'll need/want.
A foot shorter would 'work'.... but not well - even running deep you'll lose 'girth' due to lack of projection.
Faster is online now
post #3 of 7 Old 02-18-2013 Thread Starter
Yeah, I could see that turning into a bit of a mess. Oh well, was a pretty much brand new pole for $100, but since I don't even have a spinnaker (yet) I guess I'll wait for something more suitable. Or just look at an asym or perhaps a big light-weight genoa.
Orange Crush
1974 C&C27 MkII
post #4 of 7 Old 02-18-2013
If you're thinking assym then you could use that pole to fashion a deck mounted prod for it.. With 7 feet on deck and a 2 ft extension you shouldn't need any kind of bob stay. For $100 if it doesn't work out you can easily sell it again.
post #5 of 7 Old 02-18-2013 Thread Starter
Hah, yeah, it'd probably just tear the front half of the deck off
Orange Crush
1974 C&C27 MkII
post #6 of 7 Old 02-19-2013
Old as Dirt!
svHyLyte's Avatar
Paul--
Considering that the cost in poles is the end fittings, not the tube, if the diameter is right I'd by the pole, detach the end fittings and simply buy a longer length of tubing which is relatively inexpensive. In that manner you could have a properly sized pole for your yacht for much less than half the cost of new. (E.g. Ultra end fittings for a 3" diameter pole sell for upwards of $374.00 USD or $744.00 for just the two ends of a pole).
FWIW...
svHyLyte is offline
post #7 of 7 Old 02-19-2013
I don't discuss my member
zz4gta's Avatar
APS - Spinnaker Pole End Fittings
has end fittings for 3" pole quite a bit cheaper. However, I'm with svHy on this one, get the pole, pull the ends and reinstall on a properly sized pipe from the hardware store. Done.
Merit 25 # 764 "Audrey"
zz4gta is offline
whisker pole or spinnaker pole ltgoshen General Discussion (sailing related) 11 06-20-2012 01:38 PM
Using spinnaker pole to pole out jib when sailing downwind... sweetdreamyamaha Seamanship & Navigation 5 09-08-2010 10:39 AM
Using a spinnaker pole instead of a whisker pole aphil138 Gear & Maintenance 14 03-31-2008 02:51 PM
Wanted a Whisker Pole and a Spinnaker Pole matthiesen Gear & Maintenance 0 02-22-2008 02:10 PM
Whisker pole sizing blt2ski Gear & Maintenance 12 06-12-2007 03:28 AM
