Storing spare propane tank - Page 3 - SailNet Community
 8Likes
post #21 of 36 Old 02-19-2013
Re: Storing spare propane tank
Originally Posted by deltaten View Post
Saw some in pix at my gas dealer the other day. I was asking about squat, 11# cylinders. They were pricey enuff! I'd hate ta see the price on FG tanks! I was inquiring originally about litle aluminum tanks.. no joy, so....
The f/g tanks are less than aluminum.. more than steel but they never leave rust stains, are very light when empty, and you can actually see the level of the liquid propane inside. Our 12 pounder was $150.
Faster is online now
post #22 of 36 Old 02-20-2013
chef2sail's Avatar
Originally Posted by kellysails View Post
Yet another excellent idea! From you folks I am getting smarter every day, and I can't wait for tomorrow. Damn nice idea!
For my next project, I have a magma grill and I was thinking about how I was going to fit a Tee in the original tiny propane locker, brilliant! I will just hook it to the spare, dang!
Remember to step down the pressure if your Magma is a low pressure model like mine. You have to get an adamptor and take the venturi tube off the grill also. I lave the hose connected to the T coiled on top og the 2nd propane tank in its locker. When we use the grill, uncoil the hose, step the control into the slot on the grill gas intake, turn the valve on...voila...No big deal
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #23 of 36 Old 02-20-2013
Tundra Down
downeast450's Avatar
A real propane cylinder or a 'green' campstove bottle? While neither should be stored below, the latter can be more dangerous.
We made racks that held the cylinders to the rail at the transom - out of the way and utterly vented!
Faster, Could you share a bit of detail of the design and construction of your propane racks?
Down
downeast450 is offline
post #24 of 36 Old 02-20-2013
Dirt Free
boatpoker's Avatar
There is a drain at the bottom of the locker that vents out through transom. Also there is significant open air passage slot, about 2" x 36" opening. It was designed as a "wet" locker. Aluminum tanks will be required. Thankfully the original is aluminum so I only have to buy one.
Exactly where is this "2" X 36" air passage slot" and where does it open to ?
Is this a european boat ?
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #25 of 36 Old 02-20-2013
Down
We simply took some 3/8" or 1/2" SS tubing and bent a circle that the bottom ring of the tank fit into, with extended arms as shown below... the vertical sections were attached the the pushpit upright with SS hose clamps. We used bungee cords to hold the tanks down on the 'hoops' but you could easily fashion something more solid... sorry for crude sketch...
downeast450 likes this.
post #26 of 36 Old 02-20-2013
scurvy dog
delan's Avatar
The main reason you don't want propane inside is that it is heavier than air, so in the event of a leak or heat expansion it will roll down to the deepest part of the bilge and stay there until it is removed, or and electrical switch triggers it.
The only way I know of removing it is to adapt an engine room blower with a long hose to vacuum it out.
shop vacs are likely to explode.
Restauranteur
Mako 236
Shamrock 26
Schucker 44 Cutter
Dyer Dhow
delan is offline
post #27 of 36 Old 02-20-2013 Thread Starter
Puget Sound Pounder
kellysails's Avatar
When compared to the Manchester Aluminum tanks, the composite versions from Lite Cylinder were MUCH cheaper. They seem a bit higher than steel.
kellysails is offline
post #28 of 36 Old 02-20-2013 Thread Starter
Puget Sound Pounder
kellysails's Avatar
Sister ship photo's
This pic is with the transom up. You can see the two vent holes down low. One vent is for the propane locker, the other is for the wet locker. Right behind the opening in the transom is a 2" x 36" gap for ventilation of the wet locker.
In this pic with the transom down, you can see the wet locker. To the left of the wet locker is the propane locker that holds one bottle.
post #29 of 36 Old 02-20-2013
rwlpatrick's Avatar
Holy cr$p, that is cool, and cheaper, wow
This is exactly why I love SN, never would of thunk it!!!!!!!!
two problems with these cylinders
one they cannot be requalified like steel and aluminum cylinders they have to be pressure tested and that costs more to do.
two they are only have a 15 year life cycle and need to be taken out of service
rwlpatrick is offline
post #30 of 36 Old 02-20-2013 Thread Starter
Puget Sound Pounder
kellysails's Avatar
It seems that my steel tanks at home are only certified for ten years. When I went to make a recent fill on one of my older tanks and they would not fill it because is was over 10 years old. Maybe there is a way to re-certify it?
propane tank gregreinhard Gear & Maintenance 5 03-04-2013 01:09 PM
S/S Propane Tank? jppp Gear & Maintenance 11 11-27-2011 05:48 PM
Storing propane tanks below deck Rockstar2011 General Discussion (sailing related) 34 06-07-2011 12:37 PM
Propane Tank Funsail C30 1 03-12-2011 10:33 AM
Propane tank Irwin32 Gear & Maintenance 10 01-21-2006 06:58 AM
