Inside the mast wiring connection-help! - SailNet Community
post #1 of 5 Old 02-20-2013 Thread Starter
rhr1956's Avatar
I'm having a hard time finding a solid and simple quick-connect/disconnect plug and socket for this. Can anyone recommend something for me. Thanks.
rhr1956 is offline
post #2 of 5 Old 02-20-2013
Re: Inside the mast wiring connection-help!
All kinds of electrical quick-connects available... see the image search below, or search for 'military connectors' too....
electrical quick connects - Google Search
Faster is offline
post #3 of 5 Old 02-20-2013
no longer reading SailNet
Alex W's Avatar
You might find it easier to run the wires through the mast step into the cabin, then connect them there. You can use a simple terminal strip that way for electrical connectors, and a coupling connector for RF connections.
I've had one boat with connectors inside the mast above the mast step and one with them below the mast step. The latter is a lot easier to deal with, the former required the mast to be lifted up slightly, connectors disassembled, then the mast lifted up the rest of the way.
Alex W is offline
post #4 of 5 Old 02-20-2013
OPossumTX's Avatar
I haven't tried these on my mast connectors but I know they work for lots of other things and make very good quick disconnects. They can be assembled stacked various ways and are polarized to prevent improper connections. They will pull apart without damage and are reasonably secure when mated.
http://www.powerwerx.com/techdata/PPFamily.pdf
Google "Anderson Power Pole" for more information.
OPossumTX is offline
post #5 of 5 Old 02-20-2013
Seņor Member
PorFin's Avatar
I faced the same problem five years ago: I used a couple of flat-4 trailer wiring plugs to take care of all the circuits (anchor, tri-color, steaming, foredeck, strobe, plus two grounds). No issues (yet )
________
'85 BYB Vagabond 39
PorFin is offline
Where does your mast wiring exit the mast? downeast450 Electrical Systems 0 02-27-2012 08:43 AM
halyards down the inside of the mast... jobi Gear & Maintenance 2 07-13-2010 04:58 PM
Water inside the mast sailak General Discussion (sailing related) 4 05-17-2010 02:19 PM
How to secure steaming light to mast with halyards inside mast. Eihli Gear & Maintenance 7 04-14-2009 03:11 PM
Deck Stepped Mast Wiring Connection 1970Columbia34 Gear & Maintenance 12 01-03-2008 08:39 PM
