Replacing standing rigging - Page 2 - SailNet Community
 3Likes
post #11 of 25 Old 02-22-2013
tommays's Avatar
Re: Replacing standing rigging
Around here the cheeep way out is to have it steped and copys made
This gives you the time to go over other items YOU MAY overlook with a for more expensive ending if soemthing is overlooked while hanging off a chair
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #12 of 25 Old 02-22-2013
bratzcpa's Avatar
I just replaced all of the standing rigging. I dropped the mast and worked on it while it was on a pair of sawhorses. I was VERY VERY glad I did it that way. I found a bunch of problems at the masthead. One thing was the cast masthead had a crack in it. I never would have even seen that had I been suspended by a bosuns chair.
I also had extreme difficulties removing the pins that hold the shrouds/stays - they were badly corroded in place by the dissimilar metals (aluminum and SS). There is no way I would ever have gotten them out at the top of the stick.
I marked the turmbuckes, pulled all of the wire, wrapped it up . . . and sent it off saying "make me a set this same length". Perfect fit - worked great.
olson34 likes this.
~markb
S/V "New Girl" on the dock
Catalina 27
bratzcpa is offline
post #13 of 25 Old 02-22-2013
Courtney the Dancer
jrd22's Avatar
It can be done in the water with the mast up. I would recommend contacting knothead here on SN. He's a professional rigger (and an honest, stand up guy) and has helped numerous people here (me included). He'll be able to advise you the best, and cheapest, way to go and can probably supply fittings and cable at very reasonable cost.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #14 of 25 Old 02-22-2013
I think it's always a good idea to get the mast out and down on an old yacht.
You find all sorts of stuff when you get to have a good look at the thing close up. When we did our 12 yr old standing rigging we refurbished the 30 yr old spar and discovered it had way less corrosion than we expected but that the mast step needed attention that we did not expect.
Also took the opportunity to replaced all the bolts in the chain plates, electrical wiring in mast etc. replace crappy old sheave boxes etc. etc.
Unless you know this yacht very, very well I think not pulling the rig and just replacing the wire is a lost opportunity to prevent trouble one day when you least need it.
Brett01 is offline
post #15 of 25 Old 02-23-2013
Stu Jackson's Avatar
Pulling the mast is always a good idea. Another reason, if your halyard is frayed, is to check and/or replace the sheaves, which on some boats is ismply impossible to do with the mast up.
Good luck.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #16 of 25 Old 02-24-2013
I,ve just bought a yacht ...how do I tell how old the rigging is exactly if there is no paperwork.?
Cabes is offline
post #17 of 25 Old 02-24-2013
Jiminri's Avatar
Not that I know the first thing about STANDING rigging but I think that's a very good reason to hire a rigger. Age may be a consideration, but I think condition is more so. Too many variables that affect life expectancy of equipment.
mitiempo likes this.
Nonsuch 30 Ultra #343 1986
West River, MD
Jiminri is offline
post #18 of 25 Old 02-25-2013
Break, curse, fix, repeat
bwindrope's Avatar
I did mine with Aeolus in the water because I had already pulled the mast a few years prior and replaced all the mast wiring. I did it just as it is described here, more or less, one piece at a time. Fortunately, I have mast steps!!!!! Can attest to Rigging Only providing good service. I will also put a plug in for Hayn Hi-Mod fittings, as they were recommended by Brion Toss and I found them easy to use. Elegant looking too.
Sheaves are good to get from Zephyrwerks in Port Townsend. Great to work with on custom sizes, and great quality. I'm getting some more from him for my boom sheaves.
I enjoyed this job immensely, and even though it was tedious, I know my rigging is solid now.
Aeolus
Gulf 32
Bainbridge Island, WA
bwindrope is offline
post #19 of 25 Old 02-25-2013
Mine is a catalina 27, so we were able to unstep the mast on our own and trailer it to the back yard, where I leisurely replaced all the rigging and lines.
Next time I might hire the yard crane to help with the unstepping, but regardless, if it all needed replacing, I think I'd want to do it with the mast down. (But I have replaced just the forestay with the mast up because when I was stepping the mast after all the replacing the lower forestay turnbuckle fitting got snagged in the companionway and bent-dang!)
donlofland is offline
post #20 of 25 Old 02-25-2013
I am currently replacing standing rigging on my Bayfield 36'. The original looks really good but it is over 25 years old and I don't trust it to sail offshore. I removed one lower shroud and one intermediate and requested riggers to make 4 identical shrouds for each with upper terminals swaged. The lower (Hi-Mod) terminals I bought from Rigging Only and will attach them myself. Once I finish with intermideate and lower shrouds I will do the upper and stays, one at the time. That is much cheaper then let professional riggers do whole project.
ntolst is offline
Replacing Standing Rigging harbin2 Gear & Maintenance 0 11-23-2010 09:44 PM
Replacing Standing rigging puff6022 Gear & Maintenance 3 05-01-2007 02:06 PM
replacing standing rigging bcbirkhauser Gear & Maintenance 6 03-06-2007 02:52 PM
Replacing Your Standing Rigging Mark Matthews Gear and Maintenance Articles 0 12-15-2002 08:00 PM
Replacing Standing Rigging Mark Matthews Gear and Maintenance Articles 0 12-22-2000 08:00 PM
