Like Tree3Likes
  #1
Old 02-20-2013
Lissa is on a distinguished road
Replacing standing rigging
We have a Cal 39 and the standing rigging is over 10 years old and the halyard has a fray. Plan to replace all rigging at once, including roller furler.
We sail frequently so want to decrease the down time. Another consideration is that we are poor so want to do this as cheaply as possible, and don't want to remove the mast.
Is it possible to do this ourselves? Did it before on a Catalina 30 with a tabernacle mast, but this is more complicated
Can get a discount at West Marine (Port Supply), but there may be a cheaper option?
Been told that Port Supply might have lower quality 316 stainless - is that true and should we be concerned?
So is it possible to do all this ourselves, including measuring? We're in Honolulu with constant winds - how can we accurately measure?
How do you start replacing cables with the mast in place?
Sorry for so many questions but any help is appreciated.
-Skipper and Mary Ann
  #2
Old 02-20-2013
fordo is on a distinguished road
Re: Replacing standing rigging
You can't replace the standing rigging unless you climb the mast and detach the shrouds and stays. You can hold the mast upright with a tightened halyard secured to the toerail but do you really want to climb the mast under those conditions? I wouldn't!
If you pull the mast you can detach and accurately measure the rigging and have new shrouds and stays made. Or you can do it youself with Stayloc or Norseman fittings.
The Pacific is large and unforgiving; do it right.
  #3
Old 02-20-2013
Cruiser2B's Avatar
Cruiser2B is on a distinguished road
If you have done it before you can do it again. Call Rigging Only or go to riggingonly.com. They will get you what you need and all the follow on support you need. I did my Alberg 30 last year with sta-locs, used old rigging as template....saved quite a bit of money and learned alot about rigging and systems involved. Good Luck!
My two lovely ladies!!
  #4
Old 02-20-2013
blt2ski's Avatar
In some cases it can be better to take the mast down, send the old stuff to where it will be worked on, then they can make new stuff.
The fact that is is windy should not matter from a measuring standpoint. As long as you are using a true steel tape measure. These do not stretch, along with they should not be as effected by the wind as a fiberglass/plastic style tape will be. Or do early int he AM, as most places the wind is less in the morning that later in the day.
Being as you are possibly dealing with PS, IIRC the only places that have rigging shops is Seattle and California. Cliff in Seattle is pretty sharp. You will need to have everything measured up from the get go correctly, or it will not get down and sent back to you correctly either.
marty
She drives me boat,
I drives me dinghy!
  #5
Old 02-21-2013
knuterikt is on a distinguished road
Why replace the furler, if it's working ok servicing it might be less money.
If the mast hasn't been off the boat for 10 years it might be time for a thorough inspection.
It's easier to do with the mast down..
Replace the frayed halyard before starting to climb the mast, You need two good halyards to climb the mast.
Don't know
If I was to do this with mast up this is the way I would do it.
  • Use tape to mark how far in the turnbuckles is set
  • Take some turns of all the turnbuckles (so the mast does not bend when you remove one shroud)
  • Rig a temporary stay using a halyard or tie a rope to the mast - use a block&tackle to tension the temporary stay/shroud (if needed)
  • Take the shroud/stay down, copy and replace
  • After you have replaced all - tune the rig
Copying the old ones is the best way to get correct length, depending on how much the turnbuckle was tightened you may adjust the length of the new one. Riggers also adjust the length for stretch (don't have this number at hand)
Use screw on fittings of good quality (stalok or ..)
Or find a local rigger to put on swage terminals
If possible I would take the mast down, don't think the "downtime" is shorter with the mast up.
My rigger (who made the new wires when I replaced my rigging), does not replace standing rigging with the mast up.
  • Easier to inspect the mast when down
  • Faster: less climbing in the mast, easier access
  #6
Old 02-21-2013
mitiempo's Avatar
Originally Posted by knuterikt View Post
My rigger (who made the new wires when I replaced my rigging), does not replace standing rigging with the mast down.
Did you mean this?
If you are comfortable in a chair or harness it is not hard to do from aloft. After loosening remove opposites in pairs for replacement. I watched a rigger (a pro admittedly) replace an entire rig on a Westsail 32 at the dock, including removing the spreaders for inspection, with a swaging machine on the dock. He had to answer my questions at the same time as well.
Brian
  #7
Old 02-21-2013
Originally Posted by mitiempo View Post
Did you mean this?
No - corrected it to "does not replace standing rigging with the mast up."
Just to clarify.
We are talking about replacing all the wires.
He has got access to mast crane at his workshop.
The total time used is less by taking the mast down, and inspecting the mast is easier when down.
  #8
Old 02-21-2013
olson34 is on a distinguished road
Lightbulb Re: Replacing standing rigging
A friend of mine replaced his standing rig at the dock, one wire at a time. He used StaLok or Norseman fittings (I forget which). I recall that he had built his own mast climber setup that functioned like the atn climber.
This was on a CT38. Big offshore performance cruiser.
So it reallly depends on your knowledge and skill level. Me - I'd hire a rigger! (And did so for our new rig.)
  #9
Old 02-21-2013
jsaronson's Avatar
jsaronson is on a distinguished road
How old is the standing rigging? 10 years is not that old unless there are issues.
  #10
Old 02-22-2013
The OP sez he/she is in Hawaii. In hot salty air, I would advise every 15 years (max) as a guideline.
Their insurance company may want it done more often than that.
You may post attachments
You may edit your posts
Replacing Standing Rigging harbin2 Gear & Maintenance 0 11-23-2010 08:44 PM
Replacing Standing rigging puff6022 Gear & Maintenance 3 05-01-2007 01:06 PM
replacing standing rigging bcbirkhauser Gear & Maintenance 6 03-06-2007 01:52 PM
Replacing Your Standing Rigging Mark Matthews Gear and Maintenance Articles 0 12-15-2002 07:00 PM
Replacing Standing Rigging Mark Matthews Gear and Maintenance Articles 0 12-22-2000 07:00 PM
SEO by vBSEO 3.6.1
