Asymmetrical - sock or furler - SailNet Community
 1Likes
  • 1 Post By overbored
post #1 of 3 Old 02-22-2013 Thread Starter
jsaronson's Avatar
I was thinking of ordering a sock for my asymm. However I came across a Harken model1852 furler that is on sale for $600.
Harken Staysail and Gennaker Furling
It only requires that you splice a line from the head to the tack and can theoretically be used with other sails.
I've used a sock, but not a furler. Given a choice, which would you use?
jsaronson is offline
post #2 of 3 Old 02-22-2013
overbored's Avatar
Re: Asymmetrical - sock or furler
those furlers are for a gennaker or staysail. the sail has to have a tight luff to be furled. if you have a asymm with a loose luff then you will need a Top down type furler. also the line used from the tack to the head needs to be a special torque rope so it will wind up without twisting. when set up correctly the furler is way better then a sock. don't think Harken makes a top down. the Karver and Colligo top down furlers work the best.
Faster likes this.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #3 of 3 Old 02-22-2013
I would also toss the selden top down furler in the mix. It isn't as good as the karver, but works fine. And is about half what karver wants for theirs.
As for sock vs furler. There is no question the furler is much easier, much slicker, and doesn't require a trip to the bow to use.
Greg
Stumble is offline
Tags
furler , sock , spinnaker
Gennaker Furler vs. Sock/Snuffer ArgleBargle Gear & Maintenance 6 07-17-2010 01:58 PM
Do I need a spinnaker sock? kwaltersmi Learning to Sail 20 10-22-2009 02:21 PM
Spinnaker Sock ERICANDERSON Gear & Maintenance 6 10-04-2009 01:23 PM
Facnor Code/Asymmetrical Furler GeorgeB Gear & Maintenance 13 11-20-2007 07:29 PM
Jib Sock titan151 Gear & Maintenance 8 06-29-2006 09:50 AM
