What strainer do I need? - SailNet Community
post #1 of 11 Old 02-23-2013 Thread Starter
Jiminri's Avatar
I have a deck washdown pump connected to a dedicated seacock. Between the pump and the seacock is a Jabsco Pumpguard strainer (Model 46400-0002). The only time the seacock is open is when the washdown system is being used.
Nonetheless, when I bought the bought the boat the surveyor included the following as a required change: "Upgrade non-reinforced plastic strainer with reinforced plastic and/or bronze strainer...."
I've looked through various catalogs have not found an obvious replacement. Any suggestions?
Thanks,
Jim
Nonsuch 30 Ultra #343 1986
West River, MD
Jiminri is offline
post #2 of 11 Old 02-23-2013
Re: What strainer do I need?
Is this something your insurer is going to insist on? Was it a survey 'must do' or a suggested 'nice to do'?
If its doing the job and you're diligent about the seacock it seems a typical RW intake strainer would be overkill. However we have a similar strainer and at one point the plastic thread-on lid developed a crack and it began to weep.
Faster is offline
post #3 of 11 Old 02-23-2013 Thread Starter
Jiminri's Avatar
The surveyor listed it under "Required" repairs and corrections so the insurer expects it to be done.
West River, MD
Jiminri is offline
post #4 of 11 Old 02-23-2013
Hmmm... The only small inline bronze strainers I can find are typical plumbing Y strainers. One of these would work, I suppose, but they are less convenient to check/clean. I suppose, depending on your area you might try simply removing it? Is the thruhull a screened type?
Faster is offline
post #5 of 11 Old 02-23-2013
pdqaltair's Avatar
Clearly, if the seacock were open and the temperature dropped, the boat would sink. And I have know those to craze over the years and fail spontaneously or for a barb to snap off too.
Moving it well above the water line might be another solution, depending on the geometry. Then you can clean it without valves.
Sail Delmarva: Easier Winterizing
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #6 of 11 Old 02-23-2013 Thread Starter
Jiminri's Avatar
Both the pump and the pumpguard strainer that is inline before the pump are in the bilge. So, moving the strainer would mean relocating the pump which is not an option. I'm not sure I understand your comment about the temperature dropping. Do you mean if it dropped below freezing? I'm not that hard core. I'm also confused as to why, if these pumpguards are such a danger, why more appropriate alternatives are not readily available. I'm just not sure what to use.
West River, MD
Jiminri is offline
post #7 of 11 Old 02-23-2013
Yes, not much available for that kind of duty beyond the various pumpguards.. not even, it seems, much in the way of competitors with Jabsco.
A typical Y strainer such as below should do the job.. just not as easy to 'see' when it needs a cleaning, but it should protect the pump and satisfy the surveyor, esp using bronze barb fittings for the hose.
Faster is offline
post #8 of 11 Old 02-23-2013 Thread Starter
Jiminri's Avatar
Thanks Faster. Is that really a strainer? Does it have a screen inside? Looks like a Y-connection to me and I don't really understand how that works. Sorry if I'm being really slow about this.
West River, MD
Jiminri is offline
post #9 of 11 Old 02-23-2013
Here's another look... the flow goes into the Y, inside the cylindrical screen, passes through the screen walls and to the outlet. To clean you open the Y, pull the screen and clean it, flush the cavity, reassemble and off you go. It's just not something you can 'look at' to see if it's fouling.
Available at any good plumbing outlet, at non marine prices!! You may not find bronze barb hose fitting there, though...
Flow is left to right:
Faster is offline
post #10 of 11 Old 02-23-2013
chef2sail's Avatar
We have this type when I installed our washdown system. If you leave the stockcock open and the weakest point is a peiece of plastic, that his concern,. This is robust as the one on our engine raw water intake.
Good procedure is to leave stopcock closed until using it also.
Intake Water Strainer - iboats
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
Sea Water Strainer joub Gear & Maintenance 14 10-22-2015 04:35 PM
New Sea Strainer - What kind? sfbaysailing Gear & Maintenance 12 04-03-2012 11:36 PM
Strainer dbruce85 Gear & Maintenance 4 12-15-2009 12:12 PM
Rebuilding A Sea Strainer Maine Sail Gear & Maintenance 2 01-17-2009 05:44 PM
Raw Water Strainer Jotun Gear & Maintenance 27 03-30-2007 10:33 PM
