What is the quietest fresh water pump? - SailNet Community
 12Likes
post #1 of 16 Old 02-23-2013 Thread Starter
Hi I have an older Shurflo diaphragm water pump that is pretty noisy. Which pumps do you find least noisy? Can the pump be enclosed into something to make less noise? I read somewhere that the reason for the noise may be due to over-tightening the mounting screws/bolts. My pump is hooked onto accumulator/bladder tank but the pressure does not last very long and pump starts after few seconds of water running on the tap. I am not too fussy about the accumulator/bladder tank so if a quieter pump is available without the need for automatic shut off I'd go for it. What others use?
Petar is offline
post #2 of 16 Old 02-23-2013
Re: What is the quietest fresh water pump?
Sounds like you need to get a bicycle pump and reinflate the bladder.. if the pump's coming on more than every 3 or 4 tap openings (exc for filling a sink, etc) then the bladder pressure is too low.
It should say on the tank what the pressure should be.. they make some nice compact bicycle pumps with built in gauges nowadays..
All these pumps make noise.. no reason why you can't mask the noise with an insulated enclosure, but a properly setup accumulator really quiets things down since the pump runs far less often.
jrd22 likes this.
Faster is offline
post #3 of 16 Old 02-23-2013
turophile
This one?
mr_f is offline
post #4 of 16 Old 02-23-2013
Courtney the Dancer
jrd22's Avatar
Or this
Whale Marine - Products
I agree with Faster, if your pump is coming on that often the bladder isn't working properly. Most of the noise from a Shurflo is vibration from whatever it's mounted to, try to isolate the pump and allow the rubber feet to absorb the motion.
chef2sail likes this.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #5 of 16 Old 02-24-2013
I want to hear the pump, so I know if it running when it shouldn't be.
Jeanneau 54DS
Minnewaska is offline
post #6 of 16 Old 02-24-2013
snake charmer, cat herder
zeehag's Avatar
shur flo makes noisey and quiet pumps. i was fortunate that this bot came with a quiet one. i lived on a boat with a noisey pump long ago--only good thing about noisey pump is that you know when you leave it on....
and if your pump is always making a few bumps, try seeking the leaks--could be a hose clamp, could be a pinhole in a hose..could be anything..if the water comes on and doesnt flow nicely, there could be a nice lil air bubble in your pump....i had one of those after running the tank out of water...didnt prime it correctly and had a nice fat air bubble..fixed it and perfection.
formosa 41, cruising tropics
zeehag is offline
post #7 of 16 Old 02-24-2013
If noise if coming from mounting ,try mounting pump on a separate panel and rubber mount that .
Capt Len is offline
post #8 of 16 Old 02-25-2013
Old as Dirt!
svHyLyte's Avatar
Actually, you can mount the pump on two lengths of 2" (non-wire reinforced) hose with the ends cut off on the diagonal and screwed/bolted to the sole. The flexibility of the hose will substantially reduce the "pounding" noise of the pump. One just needs ensure that the waterlines have enough slack on either side of the pump to flex without damage to the connections. In addition to checking the accumulator bladder, you might also check to ensure that your pressure switch is operating properly and not activating for an unnecessarily high pressure.
FWIW...
svHyLyte is offline
post #9 of 16 Old 02-25-2013
chucklesR's Avatar
I'd rather hear the thump than find 100 gallons of water consumed by a child brushing his/her teeth.
chucklesR is offline
post #10 of 16 Old 02-25-2013
JimMcGee's Avatar
It may just be the age of the pump. I replaced ours last year when the old one died and couldn't believe how much quieter it was.
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
Fresh Water pump for Universal M-12 jackytdunaway Diesel 10 05-24-2011 12:25 PM
Fresh-water pump issues PolarisOne Electrical Systems 4 08-21-2009 01:14 PM
fresh water pump problemo... sailhog Gear & Maintenance 5 03-14-2009 09:50 PM
Fresh water pump question poopdeckpappy Gear & Maintenance 21 01-31-2008 04:59 PM
Fresh water pump for Jeanneau SO 372 russort Gear & Maintenance 0 07-24-2007 11:12 PM
