iPhone4 and iPad2 w/o 3G - Page 3 - SailNet Community
 3Likes
post #21 of 26 Old 03-07-2013
Re: iPhone4 and iPad2 w/o 3G
Originally Posted by strandedsooner View Post
I think some of the people are saying their ipad gps works great for them even when the 3G and wifi are turned off. Just to clarify what they were saying.
That is exactly what we are saying.
Everyone is entitled to share their experience, but I've used mine extensively and its been amazingly accurate, more than I expected. I do not consider it primary navigation on the water, but I've often compared it to my chartplotter and its never been anything other than dead on the same. I have needed it to bail me out of a chartplotter failure once.
Further, I've cross checked it at altitude in the cockpit with a program that is heavily used by general aviation pilots and compared it to my panel mounted certified GPS. Again, identical. There is no cell signal at those altitudes.
Jeanneau 54DS
Minnewaska is offline
post #22 of 26 Old 03-07-2013
Funny you should mention that, because that's where most (but not all) of my experience using these devices away from other sources of information is. I flew fairly extensively with an iPad in the cockpit that we used for chart information (with paper backups).
We actually had 3 sources of GPS data. The primary "FAA approved for IFR" GPS built into the panel with RAIM monitoring and all that good stuff, another handheld unit used to rx weather (the wx receiver for the built in unit is $11,000!), and of course the iPad. We routinely flew a handful of routes, mostly the same over and over.
There were cases that the iPad worked perfectly for the entire flight, obtaining a fix on the ground and maintaining it in the air with an accurate altitude and location. There were a lot of times that wouldn't be the case, it'd do what I described earlier and this occurred frequently over a variety of weather conditions and times of day. The app we used would show your fix on the selected backdrop (charts, terrain, wx, etc) and at the bottom display GPS altitude, ground speed, accuracy, and a number of other configurable options. I usually left "accuracy" on and it would vary between 5 miles and 100 miles on a regular basis, the location on the chart changing as a result. While I didn't keep a log of how many times it did this, I'd say it was close to 50% of the time. I was never able to narrow it down to a specific environment condition. When it happened, the built in GPS never issued RAIM warnings (and no NOTAMs for GPS outages), so satellites were visible.
Anyway, you are entitled to use what you want, obviously. I wasn't going to respond any further until I saw this comment and felt it was worth explaining a little more. I know plenty of people who trust the GPS on their iPad, including at least one fool that shoots instrument approaches with it, they've survived OK thus far (people do dumb things in airplanes too). My standard isn't based on "it works once", though, I've known of enough people who did stupid things a handful of times and gotten away with it, then their luck ran out eventually. Note that I wouldn't consider using mobile phones as a source of nav information in this context "stupid", I just wouldn't do it, the tolerances are a little different than aviation in most circumstances and hopefully you know where you are without the GPS.
All that said, I've had our primary GPS (which cost around $20,000 installed) fail as well and had to rely on other navigational sources. I was able to identify the failures because I was monitoring our location using other non-GPS sources of information, even before the RAIM warnings kicked in. I guess it's a matter of how tolerant of failure you are and what your requirements are, but my personal experiences lead me to believe using it for anything beyond finding the nearest place to eat is unsafe in any context. YMMV.
Shinook is offline
post #23 of 26 Old 03-07-2013
I think the difference might show up if you travelled a long distance with the IPad or IPhone off, then turned it on without WiFi or 3G enabled. I think you would then see how long it takes to get a fix with only the GPS.
I have done that (not deliberately) and it does take several minutes for my IPhone to get a fix in that situation.
I've never been out of cellular coverage and checked the accuracy though. Once I realise that 3G is turned off I have always turned it on in a hurry.
In my experience with Navionics on my IPhone I have found the accuracy to be excellent at all times, but as mentioned I am never out of cellular coverage AFAIK.
Tymadman is offline
post #24 of 26 Old 03-07-2013
Minnesail's Avatar
I have a 1st generation iPad 3G that I've used with the MotionX app in the Apostle Islands on Lake Superior. Although there is now some limited cell coverage up there, the first two years I used it there was absolutely no cell signal. I found it to be very accurate. At the marina it even placed us in the right slip. Overnight it would show our little swings at anchor. It never jumped around, it never failed to give a location. The only quirky bit was the elevation readout which would wander up and down, something you're obviously not doing on a lake.
Minnesail is offline
post #25 of 26 Old 03-07-2013
Ipad should never be used for nav in an airplane. I've only cross checked it.
At 8 kts on the water, no problem.
Jeanneau 54DS
post #26 of 26 Old 03-07-2013
No more curry buffets
Ritchard's Avatar
For Apps, I have been thrilled with iSailor on both my iPhone and my iPad. The app is free, they are really in the charts business. However, US Charts are cheap as borscht because they are just the free NOAA charts in proprietary format. We have to pay more in Canada because Canadian Hydrographic Service charges for their charts. Still, for the excellent functionality of the app, paying $25 for a huge region of Canadian charts is peanuts. I think US regions are like $5 apiece. (Hmmm, two food metaphors, did I forget to eat again?)
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
