Lewmar winch needs line gauge reduction - SailNet Community
post #1 of 3 Old 02-25-2013 Thread Starter
Hello Everyone
I am working on an 1987 Nuator Swan 46
It has a large number of Lewmar winches.
These winches have the following problem.
Since the winches where built, rope (line) technology has advanced to the point where the thicker one inch rope is no longer required.
the previous owner has gone ahead and replaced a bunch of the one inch line with 3/4 inch line, however the self tailing mechanism one the inches is still designed to accomodate 1 inch line. This means that the self tailing mechanism does not work a lot of the time.
Is anyone aware of a kit to replace the self tailer with a narrower one?
Lewmar themselves where no help and recommended we replace the winches.
We where thinking of taking the aluminum inserts to a machine shop and getting them shaved down.
Has anyone encountered this problem before? Any known solutions?
Thank you
Andreas
AndreasNYC is offline
post #2 of 3 Old 02-25-2013
chucklesR's Avatar
Re: Lewmar winch needs line gauge reduction
You might need to replace the top end with what Lewmar is now calling it's 'wavespring' jaws, they self adjust due to spring tension.
Or, if you are lucky you can just get a new jaw kit
Winches products
Like ropes, winches have changed in the last 25 years
chucklesR is offline
post #3 of 3 Old 02-25-2013 Thread Starter
I got in touch with Lewmar, and they stated that there are no parts to serve this purpose available for winches of this vintage...
We are left with trying to find a machine shop that is willing to thin the inner parts...
If anyone can recommend a good machine shop in the Caribean let me know
We will be in the virgin islands and st martin first.
A
Lewmar winch parts jamesjle Gear & Maintenance 4 08-08-2012 01:23 PM
Older Lewmar 43 nst winch santana30RI Gear & Maintenance 6 12-11-2011 08:57 PM
Lewmar winch Foxsea Introduce Yourself 4 06-06-2011 12:19 AM
old lewmar winch mystery davester Gear & Maintenance 9 04-22-2009 07:45 PM
Lewmar Self tailing winch line size don712865 Gear & Maintenance 9 07-22-2008 03:53 PM
