08-31-2007
K1VSK-
You might want to re-read the original post. He says:
When we went down to the boat this weekend, the water had a strong sulfer like smell. I assume that this is related to bacteria or other life in the water. I''m going to add a two stage filter to part of the fresh water system, but would appreciate suggestions on how to avoid the problem.
The smell is coming from the WATER, not the TANK...
Originally Posted by k1vsk
Smells are often mis-attributed to the tank(s). If you cleaned it out thoroughly, that would only confirm that. A smell so pervasive is more likely coming from under then tank, particularly as it had leaked in the past, or in hidden spaces such as under a hull liner. Sounds like you need to investigate further.
