Chain Plate Replacement - Page 3 - SailNet Community
 5Likes
post #21 of 36 Old 02-27-2013
sailvayu's Avatar
Re: Chain Plate Replacement
I have had a couple of people ask for the link to my article but the restrictions here will not allow me to posts links or reply to PMs till I have 15 posts. So if you are interested just google project boat zen and you will find it. Sorry about that but best I can do. And to the mods i really am not here to spam but as I run a board too I completely understand. I'm just here to help when i can.
Capt. Wayne
sailvayu is offline
post #22 of 36 Old 03-04-2013 Thread Starter
casey1999's Avatar
FYI,
Over weekend starting pulling my chain plates.
The lower forward shroud chain plate always has some rust staining on the deck so wanted to take a look.
Here are pics what I found. Seems to be a stress corrosion crack at the rusty area. The crack occurs where the chain plate has a sligth bend for alingment to the wire (shop made bend). This chain plate is about 6 years old and has about 30,000 miles on it.
One of the attached pics has another chain plate next to the existing (this was taken after I polished the existing plate some to clean it up). This old chain plate with no wire attached was on the boat when I bought her (in storage). You can see some corrosion, and there is a small crack running width of the chain plate. There is an indentation near the crack- indent was made when bend was done by shop, probaly while on the break machine. Seems both crevice corrosion and stress corriosion happened on the old chain plate that was stored on the boat. All the corrosion is occuring in the deck penetration area (where water could collect).
almost certain the chain plates are 316 ss.
Plan to replace all my chain plates.
casey1999 is offline
post #23 of 36 Old 03-12-2013
Does anyone have info or experience with common copper-nickel alloys like 70/30 or 90/10 in this sort of application?
oldfurr is offline
post #24 of 36 Old 03-12-2013 Thread Starter
casey1999's Avatar
http://www.copperinfo.co.uk/alloys/c...-and-70-30.pdf
Looks like that is a copper tube spec. Have not looked at complete spec but probably cannot get in bar form (only tube) and probably does not have the needed strength. The only copper alloy I know of for chain plates would be bronze (best is silicon bronze).
post #25 of 36 Old 03-12-2013
Thanks for the fast come-back.
I asked about that alloy as I remember it from a few decades ago being touted by (Bruce Roberts?) a build it yourself boat plans outfit as a no coating needed corrosion free replacement for steel in building a boat, I could easily be mis-remembering the metal specified but if I got it right then it must have been avail. in plate form, at least in AU.
oldfurr is offline
post #26 of 36 Old 03-12-2013 Thread Starter
casey1999's Avatar
ASTM B122 C76200 bronze plate,View ASTM B122 C76200 bronze plate,TG Product Details from Tianjin Tiangang Guanye Co., Ltd. on Alibaba.com
Looks like you can get plate, but costs would be a lot. This material is copper/ nickel both very expensive materials. Note the company that sells it refers to it as a bronze. Similar to bronze but the nickel would raise the cost.
post #27 of 36 Old 03-13-2013
The C76200 is a VERY heat temper dependent metal, with yield strengths ranging from 21,000psi to 110,000psi. This makes is non-suitable for use as a structual metal, unless a huge amount of engineering is done. The upside is that the lower limit is similar to aluminium, so you could borrow a lot from aluminium design. But the price premium would be huge.
Greg
Stumble is online now
post #28 of 36 Old 03-17-2013
midlife crisis member
AllThumbs's Avatar
Keep it simple. Put in what you took out. Go with stainless.
AllThumbs is offline
post #29 of 36 Old 03-18-2013 Thread Starter
casey1999's Avatar
No way I am going with stainless. The last 316 SS chain plate only lasted 6 years. I will go with silcon bronze or titanium.
post #30 of 36 Old 05-21-2013
I'd go with titanium, but I would avoid AlliedTitanium. I went with them and placed an order which took a month for them to tell me was not started. Since I had to remove them to measure, I was stuck unable to sail on their word they would be done in 15days. Bleh!
I ended up finding a local place that will have them to me in two days.
If you want the long drawn out version:
http://www.sailnet.com/forums/showth...alliedtitanium
talonawd91 is offline
Chain Plate Ideas FullandBy Gear & Maintenance 15 02-02-2011 10:32 AM
Chain plate help atlanticcruiser Gear & Maintenance 15 12-20-2010 12:46 PM
Chain plate problems? pander1203 Pacific Seacraft 40 11-05-2009 01:22 AM
Chain Plate (Not) davidpm Gear & Maintenance 2 04-14-2009 06:52 AM
Chain Plate Replacement jsutor Gear & Maintenance 1 04-30-2005 03:40 PM
